Question about JVC Audio Players & Recorders
Manual for JVC QL-Y55F
Operating Manual for Turntable JVC QL-Y55F
  • 8,197 Answers
You can get the manual here on link below. at the bottom. You might need to open an account for free.
http://www.vinylengine.com/library/jvc/ql-y55f.shtml
Posted on May 04, 2010
Testimonial: "Thank you so much for the quick response. Indeed this will help me in setting-up the turntable again."
I have a jvc turntable QL-F320 and the power does not come on. Is there a fuse or something easily replaceable for this?
There will be yes! But if it is as simple as replacing it, I would doubt.
There's a service manual for the model on e-bay at the moment!
If you get stuck.
http://www.ebay.co.uk/itm/JVC-QL-F320-QL-F320B-turntable-service-manual-original-/131584946151
Mar 22, 2016 | JVC Audio Players & Recorders
What is the stylus weight adjustment and tracking weight for jvc ql-a2 quartz auto return?
Balance the stylus, then calibrate the counterweight to 0. Then turn it counter clockwise to 2. For the antiskate knob, set to 2. Use the inner numbers for an elliptical stylus, use the outer numbers if you have spherical stylus. Hope that helps, feel free to ask about anything :)
Sep 05, 2014 | JVC Vintage Ql-a2 Quartz Auto Return...
I have a JVC QL-L20B turntable, hooked to receiver directly and plugged through cable, cannot get any sound except very faint from turntable itself, any suggestions.
SINCE I DON'T HAVE THE TURNTABLE IN FRONT OF ME AND NOT BEING FAMILIAR WITH THIS PARTICULAR TURNTABLE, I CAN GIVE AN EDUCATED GUESS. WITHOUT GETTING INTO THE CONFUSING ELECTRONIC SPECIFICS, ABOUT PREAMPS, ETC. REMOVE THE TURNTABLE PLATTER. UNDERNEATH IT, IF I'M CORRECT, THERE SHOULD BE A SLIDE SWITCH. IF THERE IS, SLIDE TO THE OTHER POSITION FROM WHERE IT IS CURRENTLY. PUT THE PLATTER BACK ON, TURN ON YOUR SYSTEM AND SEE IF THAT SOLVES YOUR PROBLEM. IF NOT, YOU MAY NEED TO BUY A PREAMP FOR YOUR TURNTABLE. HOPE THIS SUGGESTION HELPS
TIM
Jun 13, 2014 | JVC AL A158BK Turntable
JVC - Turntable - QL-F4 - Noise coming from the motor ?
You don't say whether your turtable is grounded by a separate wire but in some cases grounding is necessary to eliminate hum.
Feb 25, 2014 | JVC Audio Players & Recorders
I have an older QL-45 turntable that needs tone arm adjustment- I don`t know how to set the weight so it doesn`t lower down to album so hard or heavily
I can't find the specific turntable. Who makes it?
This should work with some modifications for your specific controls...
Make a note of the tracking force setting.
Make sure the turntable is level.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Stylus Pressure/Tracking setting to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
Apr 11, 2011 | JVC Audio Players & Recorders
JVC QL-Y55F turntable dead. Suspect Power Supply I.C. STK-5416. What are the outputs supposed to be for this device??? Is there any source for this part? email address: patandterry@comcast.net
I googled it and didn't find a data sheet for it. Though lots of sites claiming they have it. But I did find the IC for sale on E-Bay for around £10 plus P&P. At that price I would get it and fit it anyway.
Feb 21, 2011 | JVC Audio Players & Recorders
Jvc ql-a5 service manual wanted, the arm it return to midlle of disk instead begining.
I had the same problem, you have to open the turntable, there's a rubber piece that pushes the arm to the arm rest. It becomes sticky with the years, and when this piece of gear goes back to the normal position, it takes the arm to the center with it. just clean the tiny piece of rubber or put a piece of paper on it.
Sep 24, 2009 | JVC Audio Players & Recorders
Looking for manual for a JVC QL-A2 turntable
www.vintageaudiomanuals.com
if you email this company on there site there let you no avilability of it but i think itll cost you mate
Aug 08, 2009 | JVC Audio Players & Recorders
Table does no rotate
If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
May 18, 2009 | Audio Players & Recorders
834 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
