Question about Fellowes Powershred 320C Shredder
How do you set the cutting shaft timing on a C320
How do you set the cutting shaft timing on a fellowes C320 confitti cut paper shreddar. Been breaking 37850 gear and 37849 gear
  • 41 Answers
Email cooksmobileshred@bellsouth.net with the sn and your fax no
Posted on May 10, 2010
How do I stop shredder from spitting documents in and out?
Try cleaning the cutters well. This will require you UNPLUGGING the shredder. Turning it (the top feeding-cutting) part upside down and removing ALL paper and if you see paper clips or staples-REMOVE THEM! You will need to start the motor several times to move the cutting blades around for a complete cycle to make sure you have removed all debris from the cutting blades.
If this does not work you may have an electrical problem you will not be able to solve. Look for your shredder number in the link provided below and download.
Fellowes Shredder Manuals
Sep 12, 2014 | Fellowes Powershred SB-87Cs Shredder
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
The cross cuts are not working
It sounds as if the gears that turn the cutters is either broken or is turning freely on the shaft w/o engaging the cutters. If this is the case you will have to replace the gear(s). The cost of the gears may entice you to buy a new or refurbished shredder. Below is the manual for your machine, it may be of some help-just maybe.
Feb 13, 2014 | Fellowes Powershred 99Ci Cross-Cut...
Fellowes Powershred 220 gives a perfect cut on half of the paper only? How can this be fixed to give a perfect shred across a whole sheet of A4 paper? Can anyone help?..PLEASE..
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
Paper is passing through shredder without being shredded
Damaged bearings on the cutter shafts have allowed gaps between cutter shafts to prevent proper shredding, I think.
Apr 30, 2010 | Fellowes SB95C Cross-Cut Shredder
Motor and cutter do not rotate - strip cut model
Soak the clog with dishwashing detergent and a little bit of water overnight. This should dissolve the paper.
Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
Hsm 225.2 jerks in & out 2-3cm and wont eat paper!
try oiling the cutters...this helps out with the shredding of paper...also make sure properly mounted on bin, try resetting the shreddar, unplugging it and then plugging back in...check to make sure no paper or anything stuck in shreddar and make sure no broken gears..if this doesn't work and your shreddar is under warranty it would be a good time to call the warranty company
Apr 13, 2009 | HSM 225.2hs Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Only one-half (righ side) of the shredder works, left side does not shred
Fellowes has a five year warranty on the cutting block of their shredders. (The cutting block is that part of the machine that actually does the shredding of the paper) Take it back to the store where you bought it ans they should either replace the cutting block or exchange the entire machine, but it will take about a week or more, depending on where you are located. At least it shouldn't cost you anything.
Sep 05, 2007 | Fellowes Powershred 480 Shredder
Fellowes Powershred 320C Shredder Logo
217 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
