Question about Maximatic Elite 8oz. Deluxe Popcorn Trolley Popcorn Maker
The kettle isn't getting hot. The light works and but the kettle won't melt the butter.
  • 12,061 Answers
Ok, well most thing with an element are pretty easy to troubleshoot, you need to check, there is Power to the Element, Check for any "Thermal Fuses" Check wiring to Element, essentially , at where they wires join to the elements ends. Check the Element, it should have some resistance, anything from 7 14 OHMS would be OK, usually elements fail, open circuit. Check Thermostat too, see if it is opening and closing at the desired temperature. The thermostat and brain are the only things that can stop things.
Posted on May 04, 2010
Don't have a manual need to know how to operate Do I add oil or butter in bottom with the corn if so how much?
the ratio for popping corn with oil is three parts corn to one part oil . So a 6 oz kettle you would use 6 oz of corn seed to 2 oz of oil. Don't use butter to pop, it will burn.
Apr 27, 2016 | Kitchen Appliances - Others
Cordless electrica tea Kettle---cord on heating element gets hot when in use.
  • Be careful, the type of wire in use may melt the insulation and cause a short/shock.
Jul 24, 2015 | Cuisinart Kitchen Appliances - Others
Why were Bulbs so hot they melted the lens and melted butter.
most likely door was left open or door switch is faulty leaving light on when door was closed. also check bulb for proper wattage while your in there
May 11, 2014 | Refrigerators
1.7 l cordless kettle model JKC930C lid release does not work
Had same issue on 2 B&D JKC930C kettles. Just push in button (hidden under front of lid) located in the centre above the spout with a butter knife and the lid will open.
Jul 12, 2013 | Applica Black And Decker Cordless Electric...
Fugitronic automatic dispensoing hot water pot won't heat
The partial answer to your stated problem is that after 3-4 years of use it is possible that the heating element has worn out
Mar 08, 2013 | Fujitronic Automatic Dispensing Hot Water...
I melted some butter in the oven, it dripped into the burner holes and now they won't light.
i would let do this by specialist,to clean the burner.
butter can also ignite or you can get gas bubbles,not safe
Jul 26, 2012 | Stoves Ovens
I need the proper fuse letter/code for right rear light...2004 jeep cherokee
what type of light? turn signal,taillight,or brake light. if the right rear isn't working but the left rear is on the the brake light or the taillight then the problem isn't the fuse(the share the same fuse). may want to check the bulb socket on the right rear. the contacts get hot and melt the socket and the housing.
Aug 13, 2011 | Jeep Grand Cherokee Cars & Trucks
Can you oil or butter in with popaire 2,
(BUTTER chamber thing) The little rectangular scooper-looking thing on the slope of the top is where you can put a chunk of butter that will melt from the hot air and drizzle into the popcorn popper as the popcorn is popping. My dad said you cant use oil in it
May 02, 2011 | Microwave Ovens
How to make stickytoffee pudding
Ingredients For the pudding For the toffee sauce Preparation method
  1. Preheat the oven to 180C/370F/Gas 4.
  2. Mix the dates, bicarbonate of soda and the water together in a bowl and leave to soak for ten minutes.
  3. In a clean bowl, cream the butter and sugar together until light and fluffy.
    Technique: Creaming butter by hand
  1. Watch technique 0:50 mins
  2. Still stirring the butter mixture, gradually add the eggs, making sure they are well mixed in.
  3. Still stirring, gradually add the flour, then add the date mixture.
  4. Pour the mixture into a 20cm/8in square cake tin. Place into the oven and bake for 35-40 minutes, or until cooked through.
  5. To make the sauce, melt the butter in a thick bottomed pan over a medium heat.
  6. Add the brown sugar, vanilla pod and cream and stir well. Simmer for five minutes.
  7. To serve, spoon out a portion of the pudding onto a plate and pour over the hot toffee sauce.
Dec 09, 2010 | YouTube Videos
I have a Retro Series Popcorn maker, new. Can you tell me the kettle size in OZ, 2,3,4 etc. I have pre-measured packets given to me that are for a 4 oz Kettle. Thanks Dan Martin
Hello Dan, According to the manufacturer specifications, your popcorn popper has a 2 ounce capacity kettle. so you should be able to take those premeasured packets and by using exactly (close enough) half, get the desired results of pop corn out of your popper.
If you also want to use your own popcorn, here's some directions that will let you do that also.
First, turn on the popper and add 1 teaspoon of oil or butter, you can also use Land O' Lakes Margarine as it doesn't burn the popcorn like most butter will do so this is a personal preference (so you can use whatever your preference is but it must be melted). I've not tried it un-melted but I don't think it would work too well.
Then add ¼ cup of unpopped popcorn, brand doesn't matter. Wait and within 5 to 10 minutes it will hve popped.
Hope you find this Very Helpful and best regards!
Jan 01, 2010 | Helman Group RKP-630 Popcorn Maker
Kitchen Appliances - Others Logo
362 people viewed this question
Top Maximatic Kitchen Appliances - Others Experts
raysaw
Irene Tulloch
ELECTRICKS
ELECTRICKS
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
