Question about Fuji FinePix S7000 Digital Camera
Pictures get ghost image & colour veriation - Fuji FinePix S7000 Digital Camera
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 241 Answers
You get a picture with sharp and correct colored parts as well as parts blurred with wrong colors?
I assume this only happens indoors, when you use the flash?
It sounds like you are using Slow Synchro flash mode.
Try switching the flash mode to Auto instead.
Posted on May 04, 2010
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
Jul 26, 2012 | HP Color LaserJet 5550hdn Printer
Red patches & ghost images
Try changing the input device to something you are sure works. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
My t.v. picture was coming i ghost shade why?
If you are using antennae check the direction. If this is a cable input , then with a DVD , if all these show a ghost image, then the convergence of the TV section must be checked. Possible fault in the picture processing -( Y amp luminance)can lead to ghost images.
Jan 29, 2011 | Televison & Video
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Oct 11, 2008 | Televison & Video
Colour printing gives ghost image
Are you using genuine Brother color cartridges? If you are, then try different paper (20 pound laser printer paper or plain paper copier paper rather than inkjet paper,) Also, do not use recycled paper. If that does not work, you may need a new imaging (OPC belt) unit, or a new fuser assembly. Check your owners manual about when to replace the imaging unit or fuser. It is usually after 60, 000 prints have been run.
Jun 09, 2008 | Brother MFC-9420CN All-In-One Laser...
Tri coloured ghosting
maybe...it might need service mode aligning be a tech
Jan 02, 2008 | Televison & Video
Fuji FinePix S7000 Digital Camera Logo
95 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
