Question about Necchi Sewing Machines
Threading the bobbin- Necchi 535FA
I have a Necchi 535FA and I'm fairly new to sewing. I have the bobbin threaded and replaced, but how do I get the thread to go up through the bottom hole?
Hi - I have a 510 Necchi sewing machine - how do a fill the bobbin?
Posted on Oct 18, 2010
How do I wind a bobbin?
Actually, $10 for a manual is probably a valuable investment. It will not only help you with threading & winding the bobbin but also with maintenance and care of your machine and as well as how to use your machine. Similar brand machines thread and wind the bobbin in the same manner. So, even finding a similar Necchi and the bobbin winding method should be helpful.
Necchi bobbin wind Google Search
Oct 17, 2016 | Necchi 3101 Mechanical Sewing Machine
I have a Necchi sewing machine The bobbin thread is way loose. What should I do
Start out with a brand new needle.
Be sure the machine is threaded properly. Also, the presser foot MUST be raised before threading so the thread will seat properly in the tension disk.
The standard setting for the upper tension is the midway point between the high and low number.
If the bobbin thread is still way too loose, you can try adjusting (tightening) the bobbin case tension. If that does not fix the problem, you can probably try purchasing a new bobbin case for your machine as the old one may be broken or worn.
adjust bobbin tension Google Search
Jan 27, 2016 | Necchi Sewing Machines
Ned a diagram (or detailed instructions) on to thread a Necchi 3205FA & installing the bobbin. Thanks.
try www.sewusa.com there are threading diagrams for some Necchi models. even if yours isnt there the bobbin should be similar.
Sep 20, 2011 | Necchi 3101 Mechanical Sewing Machine
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
The needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Jul 09, 2010 | Necchi Sewing Machines
I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Aug 24, 2009 | Necchi Sewing Machines
I just replaced the belts on my Necchi 535FA, but
If the belts are not tight enough they will slip, they should all be fairly tight but not like a piano string if you know what I mean.
As you do not describe what the machine is doing wrong I can not really say any more at present, except make sure there is no oil on the belts and the machine has no tight spots when you turn it over by hand.
Jul 07, 2009 | Necchi 6015 Mechanical Sewing Machine
How to thread my 535fa
I don't even know where to start. Send me you're email address and I'll get back to you with my phone number as I don't want to post it for the world to see. I'll be able to talk you through it.
Feb 20, 2009 | Necchi 3537 Mechanical Sewing Machine
6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Nov 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
609 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
