Question about Ridgid 14" Band Saw with Stand
Rigid 14" Band Saw Stand Bounce
I bought a new Rigid 14" Band Saw but the stand top that the saw sits on goes up and down when the saw runs. I checked the wheel balance and reset the motor belt tension three times to make sure those weren't the problem behind the saw bounce. Also checked the leveling feet. But the problem seems to be a weak metal top to the stand. Any way to firm up the center of the stand top so the saw quits bouncing?
    Brigadier General:
  • 4,088 Answers
Yes, take it back to the store that sold it and get them to replace or repair the problem. Hope this helps!
Posted on Jun 25, 2010
What are all yours phone number
I ordered my band saw blades on sawblade.com . I mostly cut metal tubes and some pipe work. I used bi metal band saw blade.
May 21, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
What makes a delta 28-243F 14" band saw blade keep coming off?
The most common is wheel misaligment. The top wheel has an adjusting screw or the equivalent somewhere, and you can turn that to align the blade to the center of the wheels.
Second most common is guide problems. There are some guides that are supposed to hold the blade "just right" above and maybe below the table where you are cutting These must be set to support the blade in it's correct position as you are cutting through the material you are cutting.
3rd problem is a saw blade that has lost it's tension from being
" worn out ".
Be blessed.
May 20, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Motor replacment
Try to contact ereplacement . Or check out the motor from Baldor electric company. They have available motors. If you need band saw blade, my supplier is sawblade.com . Check them out.
Nov 11, 2013 | Delta Machinery 14" Band Saw with 1HP...
Where is the seriel number on rigid tri stand
You may want to call the manufacturer for that. Pretty sure there's a serial no.
Apr 20, 2013 | Delta 28-248G 14" Band Saw with 1-1/2 HP,...
Rigid band saw tires come off
Glue them on. You might need to replace them. They're standard for just about all brands of 14" band saws. If you do that, check into replacing the blocks that rub the sides of the blade with ceramic. They work great.
Mar 29, 2012 | Ridgid 14" Band Saw with Stand
Where can I get assembly instructions for a Ridgid 14" bandsaw. Is it a difficult procedure?
http://www.ridgid.com/ASSETS/75F0D67B60594EE78CC0C82FA864F7F5/BS14002_292_eng.pdf
Pages 15-24 are the assembly instructions for a BS14002, if you have a different model number, you will need to plug that into the search box at the top right of the screen at this link
http://www.ridgid.com/Tools/14inch-Band-Saw/
I hope this helps, if not, please repost with your model number.
Nov 27, 2010 | Ridgid 14653 14" Band Saw with leg stand
The delta universal miter saw stand will not adjust to level posi
Hi, The legs on the stand should have leveling pads on it. at the bottom of each stand legs, there is a hole which the pad goes in. you can adjust the pad by unloosening the top nut. put a level on the saw base and adjust the pad up or down to level your stand.
If this doesn’t work for you, please write back. Thanks,
Nov 27, 2008 | Saws
Motor power question
Horsepower is the maximum power produced by the motor. Saws with high horsepower ratings are good for pattern cutting and cutting down thick stock. Higher horsepower also allows the saw to cut through thick stock without bogging down or burning the wood.
Aug 27, 2008 | Ridgid 14" Band Saw with Stand
Ridgid 14" Band Saw with Stand Logo
277 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
