Question about HP Pavilion a1610n PC Desktop
Hard Drive keeps revving???
Tower went into service to replace fan under warranty. Now it keeps "revving" and I don't know if it's the hard drive or the new fan. Only revs when I use the computer. ?????
  • paulrmaudsle May 04, 2010
    The noise sounds like someone revving a car engine by stepping on and off the gas. 2 or 3 second pulses...some quite loud, others softer but all very close together. Interestingly enough, this morning it's not doing it. I did a disk defrag (hadn't been done since it got back) on the advice of another online forum so maybe that was it (?) and the hard drive was skipping all over the place. The fan that was replaced was for cooling and believe me, I am not going through that crap again with HP. $400+ for the extended warranty for them to ship it off for 6 weeks (!) to a place that is only an 8 hour drive for me (that's my rant). Thanks for your help. I'll keep an ear on it to see how long it takes for it to do it again if at all.
  • 221 Answers
Some PCs have temp. controlled fans that change speed depending on usage load.
It can be distracting but is normal for most of the newer generation PCs.
Posted on May 04, 2010
  • Robert Stout
    Robert Stout May 04, 2010
    Unfortunately, the long turn-around times are common with RMA type repairs. It is often easier on the mind (and cheaper) to skip the extended warranty, and use someone local that you trust.
    Have you scheduled the system to defrag the system regularly?
    It is easy enough to set for a time when the PC is on and not being too heavily used.
  • 4,472 Answers
What do you mean by revs? The noise gets increasingly louder? I doubt you should be hearing the hard drive. It may be a fan that changes under load or temperature. Have you contacted the manufacturer or the repair facility to inquire about this issue? Otherwise if you know someone with the technical capability. I would take the case off and you should easily be able to distinguish then if it's the fan or the drive. Do you know what fan it was that needed to be replaced? Once I have more information I can assist you further.
Thank you,
Lee
  • Lee A.
    Lee A. May 07, 2010
    Feel free to keep us updated. Also please reconsider your rating of my solution. Usually even when a hard drive is fragged it shouldn't get that loud.
    Take care and good luck,
    Lee
My daughters computer would not really work except in safe mode. She has a Toshiba Satellite laptop (L450 series). I didn't have any restore disks so I went through the Toshiba Recovery Wizard to...
You very likely have a failing hard drive. Since the recovery system is also located on the same drive, you will have to obtain a new drive from toshiba with the recovery system on it or obtain a complete recovery set of dvd's. Since the system is not under warranty, then you could probably save some money by obtaining a suitable replacement (larger) hard drive from a reputable online source (like newegg.com) and then reinstall everything from the recovery set of DVD's you get from Toshiba. Recovery set should only cost about $30 or less. A new drive will run about $50 and up. The drive is actually pretty simple to replace. Since you will be replacing the drive, you should try and copy the important files (pics, music, etc) to a portable drive (hard drive, usb flash drive, etc.)
Here is a link to see what is involved in accessing your hard drive:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/laptop-disassembly-1.htm
Aug 10, 2011 | Computers & Internet
Wont start windows hangs up on sony logo
Hi if you are comfortable opening the tower try to pull the Hard drive out and all memory except one. If you have an extra stick, swap the memory around the see if it will turn on. Bad memory and Hard drives can cause these problems. Not likely Hard drive because it shouldn't get "stuck" on the sony logo screen. If it is none of those worked , then your MB (Motherboard is bad) or processor is bad.
(if its under warranty ) i recommend you call Sony support to service /replace the broken part.
Jan 12, 2011 | Sony VAIO PVC-RS502 (PCV-RS502) PC Desktop
Hi my name is eric and i recently brought a emachine from thw walmart brand and it is makes noises when i turn it on . i think its coming from the tower inside the dvd area . is there a way to fix the...
If ?t's still under warranty take it back. It could be a hard disc issue, dvd drive, fan or power supply problem. Note that if it is hot around the pc or there is not enough ventilation then the cooling fans will be making a lot of noise so rule this out f?rst before you take it back to the service.
If it's out of warranty I woudl just keep using it until something fails. A clunking sound is normally your hard disc giving up and that is usually located near the DVD drive bay. However best to back up any important infromation you have on the pc to DVDs or other media now in case the hard drive does die as it will be expensive to try and recover lost data on the drive later.
Sep 03, 2010 | Computers & Internet
1 tb western digital hard drive is not being recognised by my com
Try plugging the external Hard Drive to a different computer and see if it would recognize the device. If not, go the store where you purchased the external hard drive to have it replaced since it is still under warranty.
Mar 26, 2010 | Western Digital My Book Essential 1TB...
Hard drive with loose usb connection
Hi there. This would be an actctual manufacturing fault. I would strongly suggest that you copy/backup all the files you want to keep, from that hard drive, to another one. Then, if it's still under Warranty from either the shop where you bought it, or still under warranty from Seagate themselves, you can send it back to be fixed, or get a replacement. If it's not under warranty, then you could always take the external case off the hard drive and see if it's something you could repair yourself. Either way, as I said, I would still strongly suggest you copy/backup any files that you want to keep.
Tim
Apr 16, 2009 | Seagate FreeAgent Pro 500GB External USB...
G-Tech G-Drive Q 1TB. Four months old, only several hundred gigs of data on it. Used primarily for video editing with Final Cut Pro. PLugged in, attached to MacBook Pro today. Without warning, drive made...
The platters on your drive collided, the only way to recover is a professional company. Google Hard Drive recovery, you will get several companies, be prepared to pay $300-500.
Mar 25, 2009 | Computers & Internet
A 100 Toshiba won't start
the motherboard is prolly cracked, i hope the laptop is still under warranty, cause you will need toshiba to service it at this point. the problem is unrelated to the reinstallation of windows.
Mar 06, 2009 | Toshiba Satellite A100-S8111TD Notebook
WD400 will not boot up
The elemets hard drives are not user serviceable and thus, you may void the warranty in doing so. Have a look on their website for the data lifeguard diagnostic software and check for possible errors. he sound you may be hearing is the heads inside the drive. If you are still under warranty, you can have your drive replaced. Make sure you have your data backed up.
Feb 15, 2009 | Western Digital Elements powered by WD 320...
Deel inspiron 6000 error 1000-0146
Error code 1000-0146 is a hard disk drive failure, you'll need to replace the hard drive. If under warranty contact Dell for a replacememt. If not, you can buy replacements at newegg or other tech sites
Jan 26, 2009 | Dell Inspiron 6000 Notebook
Computer not loading up strange symbol indicating some problem
That is the hard drive symbol. The noise is most likely the hard drive, and I would say that your hard drive has failed/crashed and needs to be replaced.
Aug 21, 2008 | Packard Bell (ATXMH28AP) Full Tower Case
HP Pavilion a1610n PC Desktop Logo
369 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
