Question about Nokia 3110 Cellular Phone
What is the formatting code for nokia 3110 - Nokia 3110 Cellular Phone
abhi2664
  • 3 Answers
SOURCE: master code for all nokia 3110
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#06# : Checking the IMEI (International Mobile Equipment Identity)
*#7780# Restores Factory Settings (Memory, language, counters are not included).
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#746025625# [*#sim0clock#]
Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#92702689# [*#war0anty#]
Press the following warranty code :
6232 (OK) : Displays the Month and Year of Manufacture (0997)
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove SIM card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key.
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Posted on Jun 10, 2008
rockfixya
  • 679 Answers
SOURCE: FORMAT CODE FOR NOKIA 3110
Here’s how to hard reset or format your Nokia mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Posted on Jan 24, 2009
  • 523 Answers
SOURCE: format code for nokia 3110 classic
Hi Friend,
There are 2 ways to format ur nokia 3110c
Step1.
1.hard reset
hard reset using this code *#7370# (ALL DATA WILL BE DELETED)
Step2.
1: Turn off your mobile
2: remove your memory card
3: Turn it on again
4: Go to Menu then Applications
5: there will be 2 folders games and collection
6: open each one seperatley and delete everything inside them>
7: Turn your phone off replace the memory card then Turn it on and have fun no more problems try it
Regards,
Ayyasam
Posted on May 30, 2009
SOURCE: HOW TO FORMAT NOKIA 3110. I WANT TO FORMAT IT.
enter *#7780# on the main screen and enter password
Posted on Jun 02, 2009
  • 30 Answers
SOURCE: Format code for nokia 3110 classic
software can solve your problem
Posted on Jul 11, 2009
Formating code for nikia 3110c
There is no format code for 3110c.The only thing is to flash the phone ..so Click here1 and follow the instruction.And here is your 3110c file.Good luck.Thanks for visiting fixya.
Aug 03, 2011 | Nokia 3110 Cellular Phone
Pls i need code 2 format ma nokia 3110 classic pls. It seem there is virus inside
there is no code for complete format for nokia 3110c
but u can soft format your mobile
code : *#7780#
Nov 26, 2010 | Nokia 3110 Cellular Phone
Hello my nokia 3110 mobile got hang and switched
my nokia 3110 mobile got hang and switched off automatically. to restore factory setting i put the code 12345 or 00000 but i shows code error. i think there is virus in my mobile. now i dont know the exact code to format my mobile. pls send me the procedure to format my my and give me the right code to format it. follwing is the information of nokia3110c: Email Id :- yogeshkumar5555@gmail.com
Aug 07, 2010 | Nokia 3110 Cellular Phone
Pls give me a nokia 3110 format code
pls give me a nokia 3110 format code
Jul 26, 2010 | Nokia 3110 Cellular Phone
Hello Sir, can plz help me with the format code fo...
you may contact the service provider........
May 21, 2010 | Nokia 3110 Cellular Phone
Format my phone 3110
its simple just enter *#7730# or *#7780# if it will ask u code then press 12345 its the default code enjoy rply soon
May 16, 2009 | Nokia 3110 Cellular Phone
Formatting
type from the right to the left #0737#*
then type the code :12345 (this code is the original code)
Nov 26, 2008 | Nokia 3110 Cellular Phone
Formate code
Formete code for softwear
Jul 23, 2008 | Nokia 3110 Cellular Phone
Nokia 3110c
the code is *#7780# n it will format your mobile ..
how can i format my nokia3110classic phone
Jul 21, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
131 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
