Question about ASUS P5GL-MX Motherboard
Hi, I have an asus p5gl mobo, my problem is it sometimes dont turn on. I need to unplug the power supply connector to mobo then on it again, some time it will last for 2 days some times 1 day. my power supply is 350w. 40 gb hdd ide, 1g mem ddr 400.
  • 979 Answers
Hello Ncp, hi, there are several reasons why this things happen, here are some possibilities, 1. your motherboard is bad or something is making it bad, (are there holes on the back of your casing where a small RAT could fit in, they sometimes pupu on your mobo, so a visiual inspection will reveal it.) 2. beside the motherboard, are there video cards, or expansion card on your mobo, check them also for this rat pupu (rat waste) 3. your power supply is bad, you have no choice but to replace it with a new or good one. Thats it, keep me posted.
Posted on May 04, 2010
Testimonial: "Thanks for the info. I will check it and i will inform you. thanks again"
In asus P5GL-MX mother board the power supply regulator ic 2 piece has been damaged (short) how would i know plz help me
Hi if the regulator ic has been damaged in your power supply even you replace that there are some electronic component where also damage because the ic will not damage where there is no over voltage flow on it. This means there are some resistor or a transistor is also shorted it advisable to replace a new one than to repair your power supply. Because even you repaired it the performance and the life span of your power supply is not stable. So it better to replace a new one.
Jul 14, 2011 | ASUS P5GL-MX Motherboard
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
Hi there,,,, i have my mobo, asus p5gl-mx. i lost my driver disk. could anyone help me please where I can download the driver for my sound, chipset n video card onboard.
Go to ASUS Downloads
Type your model into the box in the upper left. Click Search Info.
When the model number comes up in the large window, click on it.
You must then select your operating system from the drop-down menu.
A list of availble drivers will then be displayed for download.
Thanks for using Fixya.
Nov 15, 2010 | ASUS P5GL-MX Motherboard
My PC stops giving output to VGA, the key board is also dead after powering on. the mother board is P5GL-MX
hi, sounds like a power surge , unplug the computer open the case . you might need a light , now look for vga next too the vga are some capasiters sometimes after a surge they expand and leak .also look around the power plug.if every is find there, next it might be the power supply not putt out enough volts to the vga or the motherbaord . thanks hope i been some help
Sep 25, 2010 | ASUS P5GL-MX Motherboard
Asus mobo flashes on startup, no video
You should unplug the power cord from the power supply, pop out the cmos battery, switch the bios reset jumper to the 2 and 3 pins, wait about a minute, put the jumper back to 1 and 2 pins, put cmos battery back in, plug in power cord to psu and turn on pc. If you have any issues with this process please refer to your owner manual for the motherboard or look one up on their website. Please let me know if this fixes your issue.
Apr 30, 2010 | ASUS M4A77TD Motherboard
Can I use a SATA2 HDD for P5GL MX?
just like usb1 and 2, the sata2 harddrive will simply clock down to match the speeds of its port. the connections for both types are identical so there are no possibilities of problems...other then the motherboard saying "nope i cant read that", which most likely wont happen.
ohyeah...ram does the same thing too.
but honestly, if you're using a mobo thats only sata1 and you've got the dough for a new 1tb harddrive, you should consider upgrading your motherboard first...much better money spent
Apr 26, 2009 | ASUS P5GL-MX Motherboard
No boot up.
Power supply is easier to troubleshoot my local pc shop has used ones for $5 or if you have one laying around make sure you have one with the proper mobo connector 24pin will sometimes fit 20 pin as long as there are no transistors to close to plug just turn pc off unplug all drives and mobo plug in good supply and turn on if it works thats the problem if not probably mobo
Apr 10, 2009 | Shuttle SK43G (tsk43g) Barebone
HDA Driver 4 Asus P5GL-MX
Heres the link to all the drivers from asus
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
hope that helps
Dont forget to rate the solution
Aug 22, 2008 | Edirol UA-4FX External Sound System
My Asus mobo P5ld2 cant turn on
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Apr 12, 2008 | ASUS P5LD2-VM Motherboard
ASUS P5GL-MX Motherboard Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
