Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
What could be wrong ? when i turn my tv on quickly off.
What could be wrong ? when i turn my tv on quickly goes off.
    President:
  • Mitsubishi Master
  • 1,619 Answers
Replace bulb and clean dust out of all cooling fans, may require you take back off set and remove and disassemble projector inside.
Posted on May 04, 2010
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
TV won't turn on
I have Exactly the same problem. did you happen to figure out what went wrong?
Dec 23, 2009 | Panasonic CT-32SX31 32" TV
I am having problems with my Westinghouse LCD TV. When i 1st turn it on, everything is fine but after a couple minutes I lose picture. The audio is fine and continues on. I unplug the tv from the outlet...
No quick fixes. A component such as a capacitor is heating up and failing. Sometimes a cracked solder connection will work fine until it heats up and no longer sustains the connection.
When the screen goes off, shine a very bright flashlight at the screen to see if the image is still there. In many cases, the problem is the screen backlight, which consists of several CCFL tubes (fluorescent lamps) and a circuit board called the inverter (similar to a lamp ballast).
If the image is there, but the backlight is off, then you just may need a new inverter board.
Oct 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Tv turns on briefly then goes out with red flashing status light
This is exactly intermitent problem, It needs to be trouble shoot at the repair shop if the problems occurs from power supply or high voltage.It needs a lot of test and equuipement to be accurate.And also the specific parts.
r_ic7
Nov 28, 2008 | Mitsubishi Televison & Video
Picture goes intermittent after a while; sound plays throughout.
I would take it to a repair shop, they charge around $50 to look it over, and then tell you want is wrong with it and they will give you the cost to fix it. This is what I do when TV's go out. It will save you time and money in the long run.
May 19, 2008 | Sony KV-32FS10 32" TV
Panasonic plasma
If you open the back,look at the can shaped items.If any of them have the tops bulged out,they need to be replaced.This should solve your picture problem,unless there is something else wrong.What is happening,is they are heating up,and the picture goes out.I bet the longer you have the TV off,the longer it stays on?Hope this helps.Thank You very much! Tyler
Apr 06, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Power goes on than quickly turns off
Please post the make and model. Also, is there any blinking of the standby light?
Dan
Mar 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Rca television model 24v412t- or 25v511t
Thank you for your quick response.A new TV is to be shipped to me,via Jayco RV.Iam thankful for that,the wait will be a while.Better something than nothing.
Thanks Sincerely Maynard J Henning
Feb 24, 2008 | Audio Players & Recorders
Help
It's probably something wrong inside, so if you don't want to open it you will probably have to send it in for repair. Since it's only two years old, might you still have waranty on it? Try to contact the dealer to find out. If not, I fixed a similar problem on my Sony TV by opening it up, and adjusting the knobs inside. I adjusted *one at the time*, and returned it to its starting position if it didn't seem to have any effect. I finally found one that caused my TV to stay on. If you open it, be very carefull. There are components that can shock you *even if the TV is off and disconnected!* So don't touch any metal with your fingers. While you're in there, clean out any dust to reduce risk of fire later.
Sep 03, 2007 | RCA TruFlat 27F520T 27" TV
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
