Question about Zebra 140XiIII Plus Thermal Label Printer
Have 3 printers of this same model that is saying on the display "Error Condition Paper Out" The forms are loaded correctly and 2 of the printers will print for a bit before erroring out. Is there something in common? Any help would be greatly appreciated.
  • Zebra Master
  • 12,061 Answers
Posted on May 04, 2010
Hp 2410 loads paper but stops and says out of paper then paper jamb
Jamb:either of two stones, timbers, etc., forming the sidepieces for the frame of an opening.
Do you mean paper jam?
May 06, 2012 | HP PSC 2410 All-In-One InkJet Printer
I have a IBM 9068 Model S01,it is sometimes showing error code 18.If I tilt up the printer assembly during the printer power on it is ok.If I tilt down the printer assembly meaning to it's original...
Error 18 is a "Paper Edge Search Error".
1. Check document for damage and check it meets specs.
2. Check that Ribbon Cartridge is installed correctly.
3. Do "Form-Edge Sensor Service Check"
4. Do "Platen" adjustment.
Sensor Status Display:
. Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
3. Press Reject Off button until "4" is displayed.
4. Press Start1 button to shift to next digit.
5. Press Reject Off to display "4"
6. Display should now read "44"
7. Press Start2 button. The LED display indicates sensor status'
8. You will see changes with inserting paper or removing paper.
FORM-EDGE SERVICE CHECK:
Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
With no paper the LED segment is unlit.
2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
a. Form Edge Sensor -46H2648
b. Form Edge Sensor Cable -46H2730
c. Main Card -
1.46H2632 - Serial Interface
2.46H2634 - Parallel Interface
PLATEN ADJUSTMENT:
Mar 28, 2011 | IBM Office Equipment & Supplies
Correct loading of ink cartridges. Error E2
When a printer error occurs, the Alarm lamp is lit orange. The number displayed on the LED indicates the type of error that has occurred. Check the error code displayed on the LED and take the appropriate action to correct the error.
E and number (error code) are alternately displayed on the LED of MP210 series.
Error E, 2:
Cause: The machine is out of paper. / Paper does not feed.
Solution: Reload the paper correctly and press the Black or Color button.
This sounds like to simple a solution. Make sure this is the correct error code and it is not followed by another number. If problem persists check that you have removed the protecftive material from the FINE cartridge holder. Unplug the machine from the power source for several minutes. Power up. Hopefully this corrects the problem.
If not, try checking the status of your ink cartridges:
1 Open the printer properties dialog box from Control Panel.
2 Click View Printer Status on the Maintenance sheet.
To confirm the FINE Cartridge information, click the Ink Details menu.
This my give further clues to any problem.
Trust this is helpful. :)
Dec 08, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My printer says error condition paper out. But it
try to recalibrate media and sensors, run calibration, and run sensor profile, save, and restar again the printer. check if setings from the driver are correct or they can change the setings from the printer
Apr 28, 2010 | Zebra Printer 140-751-00000
Printer will not load in paper
Make sure you don't have an error condition displayed by the led lights. (see here)
Please also see the following links, that may help you to correct this error condition:
Clear jams, Clean printer, Load paper, Check the Print Queue/Spooler, Paper specs, Replace pickup roller, Replace Separation Pad, Print Config page. Parts ordering.
If you've cleaned the pickup roller with alcohol and that didn't work, try purified water instead...
Good luck, there's nothing worse than a printer that doesn't...especially when you need a hard copy.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 11, 2009 | HP LaserJet 1005w Printer
My LaserJet4250n Printer keeps printing a page recurrently. Except the former job is cancelled Manually, it prints the previous instead of the currently sent job. Moreover,it displays the following...
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Feb 25, 2009 | HP LaserJet 4250n Printer
Printer setup
Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
Error code 024-964
theres definately still something wrong with the size or the types of paper in your trays, because thats where the error codes are pointing. Make sure that the slidable paper guides are in exact position for the size of the paper and make sure that the size paper is acceptable with this model. You may also want to make sure the correct type of paper is set for each tray as well. here's the referance for this opinion... click here
May 08, 2008 | Dell 3100cn Laser Printer
IBM 6400 MODEL 9
This seems like a micro switch or sum such is not making/is making when it should or not.
The from load in a stack in the base to I guess there must be a wight sensitive device under the load platform.- stuck in or out.
Take a look at the web site.
http://www.argecy.com/index.php?pfile=6400+Parts
Dec 17, 2007 | Office Equipment & Supplies
Zebra 140XiIII Plus Thermal Label Printer Logo
494 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
