Question about Nokia N70 Cellular Phone
Lock code I have lost my received calls etc. settings, and also my voice mail, and when using the *#7780# code, I need a lock code? Where do I find that?
  • heids Mar 27, 2008
    Went for the software update at my service provider, and as warned, lost most of my data and contacts! Very frustrating,
    what is the answer for future updates ?(I had downloaded my
    data to a memory card-not much was saved!!)
    President:
  • 1,017 Answers
If your phone is asking for a code after resetting it, input your usual pin code.
Don't use Nokia secret codes, you'll create more problems than you solve. Mainly because most people don't know how to use them.
After a reset the data is lost forever.
You need to download the latest Nokia PC Suite to do a software update on your phone. It should bring back your menu.
If this is not the answer you expected, please explain precisely the problem(s)
Posted on Mar 26, 2008
  • Raysagem
    Raysagem Mar 27, 2008
    For updates, you need the product code, it's found beneath the battery, it looks like this 0522147.
    Then go to the Nokia website of your area, and follow the instructions on the site. Also read below and heed the advise, it will prevent problems.
    http://europe.nokia.com/link?cid=EDITORI...
    You need to download the latest Nokia PC Suite to do an update on your phone.
    Before updating software you should check that there’s a newer version of software (Firmware) available.
    WARNING
    When updating software on Mobs, be sure to:
    HAVE A FULLY CHARGED BATTERY INSERTED;
    PUT IT ON GENERAL PROFILE;
    TURN OFF YOUR PIN NUMBER;
    CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
    DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
    THIS CAN TAKE 30 MINUTES OR MORE.
    And obviously don’t unplug the phone from the PC.
    Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time. (if it's obvious the job is done, close PC Suite before disconnecting your phone)
    It is also wise not to use your PC while updating software, just in case the PC freezes. If the PC freezes during an update, you’re up the creek without a paddle...
    I did an update on a Sony Ericsson 810i it took nearly two hours.
    More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Phone does not ring. calls go to voice mail. how can I change this
go to settings call settings click more setting then click call forwarding.click voice call. click disable on all the four always forward , etc and you should be able to receive calls
May 24, 2015 | Samsung Galaxy Note 4G
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
How in the world do you set up voice mail on the e71
Hello Debb,
Please visit the link provide below :
http://www.gen-i.co.nz/Solutions/Mobility/Device_Documents/Nokia%20E71/Setting%20up%20Voicemail%20on%20the%20Nokia%20E71.pdf
Apr 15, 2011 | Nokia E71 Smartphone
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
HOW TO Solve auto redial Problem on samsung E1100T ,MY SAMSUNG MOBILE AUTOMATICALLY REDIALING FROM RECENT RECEIVED CALL LIST . I LOST MY ALL BALANCE.PLEASE SOLVE MY PROBLEM .
thats simple...
1.go to "call settings" in your mobile.. there if you see ..sometimes you get two options as "all calls" and "voice calls".. choose voice calls and inside this auto redial ill be there ...turn it off
2.go to "call settings" and there itself if u find auto redial ,turn it off..
if any clarifications ..mail me simplY ..."ssgodfather@gmail.com"
"DONT FORGET TO RATE THE SOLUTION.. RATING KEEPS ME ALIVE AND MAILING YOU"...
Apr 15, 2010 | Samsung SGH-J600 Cellular Phone
I activated my new Motorola w376g yesterday and
I believe you need to have a voice mail to receive calls, just set it up and have a prerecorded voice mail.
I have the same phone and it wouldnt let anyone call me tell the voice mail was set up
Dec 12, 2009 | Motorola Cell Phones
How to retrieve lost voice message on cell phone.
Though iPhone uses quite a different storage mechanism, still you can recover deleted or lost data (such as text messages, voice mail, contacts, photos etc) with a third party specific iPhone data recovery software called Tenorshare iPhone Data Recovery. I used it to recover deleted voice mails from iPhone 4s and it worked.
You can give it a shot! Download it from http://www.any-data-recovery.com/product/iphone-data-recovery.html
Here is a tutorial to guide you recover your voice mails:
How to Recover Deleted Files from iPhone
Jul 05, 2009 | Apple iPhone Smartphone
Changing message on Comdial Impact Telephone
Sounds like you are trying to change a voice mail recording. Your Comdial phone can be used on several different Comdial phone systems and with several different voice mail systems that all program and set up differently. Do you have any manuals or instructions for your voice mail system? If not, you will need to find out which voice mail you have and try to locate manuals.
To change main greetings, etc.. you would need administrative rights to the voice mail. There will probably be a password, hopefully you know it or it's still at default.
Nov 28, 2007 | Comdial 8324S-PT Corded Phone
"New Voice Mail" stuck on screen.
Called GE. Here's what's happening (at least with my phone). I use VONAGE as a carrier. VONAGE's package includes voicemail. I have my VONAGE voicemail account set up to take any call that comes in if the answering machine on my GE phone does not pick up -- for instance if I'm on the phone and I do not "flash" over to the incoming call, that caller will eventually be sent to my VONAGE voicemail where they can leave a message. (Otherwise I would either take the call, or, if not already in use, the GE phone/answering system1.gif would simpy take the message.) This GE phone is commucating with my VONAGE account and letting me know that I have a mesage in my VONAGE account voicemail. All I have to do is either go online and delete the messages (after listening to them of course) and refresh the page. Once the messsages are deleted, the carrier lets my phone know the messages are gone and the NEW VOICE MAIL prompt on the handset disappears. I suppose I can do it by listening to the messages by calling in and deleting through the touch pad on the phone as well.
Sep 23, 2007 | GE 25932 Cordless Phone
Nokia N70 Cellular Phone Logo
90 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
