Question about Dometic Rooftop RV Air Conditioner
I have a 13,500 Dometic A/C that usually blows cool air but sometimes changes sounds and blows hot air for a while before switching back to cold. What do I need to fix?
  • Dometic Master
  • 8,220 Answers
Could be the compressor overload on the way out. Or an intermittant temp control. Or it might just be a loose connection at the junction box between the roof and the base.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 04, 2010
2014 Dometic Brisk II 15,000 unit won't cool below 88 degrees
Check the unit to see if the outdoor fan and compressor are coming on. If not, check to see if power is reaching the contactor, both the high power contacts and the low voltage solenoid. Some contactors can be manually actuated, and a quick press (with a NON CONDUCTIVE ITEM) can show you if the contactor is engaging. If the solenoid is not working, check the wiring of your thermostat. When set to cool mode, there should be voltage on the solenoid of the primary contactor, sending power to the outdoor fan motor and compressor.
If the outdoor fan and compressor engage normally, then make certain the coils are free of debris and other blockages. If air flows freely and the compressor is running, feel the tubing for temperature changes. One side should grow cooler and the other warmer.
If the compressor runs but there is no temperature change, take your unit to a certified technician to check for leaks and system pressures. Roof top units typically use R22 refrigerant not R134a automotive refrigerant, which require EPA certification for purchase and dispensing.
Jun 25, 2014 | Dometic Rooftop RV Air Conditioner
What model number Dometic AC unit to add to RV?
usually 13,000 in front but if enough power and you don't mind the more expensive one go 15,000
Jun 26, 2012 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner blowing cool air
When the cooling slows down, but water is still running off, usually something is icing up. You can turn the unit off, and let it thaw, and try again. Sometimes, if the humidity is high, this is more pronounced. It sounds like you are low on refrigerant. That implies that you have a slight leak. You should have the unit serviced, and the leak repaired.
Best regards, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Dometic RM7291L not effectively cooling on 240V but fine on gas
On the back of the unit, at the bottom, there should be a panel that is removable. Inside should be a fan, the condenser coil, and the compressor. The fan has to be constantly blowing air over the condenser coil, to dissipate the heat (which it is essentially being removed from the refrigerator by the compressor)
When the entire fridge stops cooling, one of three things have happened. The fan isn't removing the heat from the coil, or the compressor isn't compressing the freon, or the freon has somehow leaked out of the system. If it is the fan, you have an easy do it yourself repair. If it is the compressor or the freon, you will probably (but not necessarily) need a professional.
Inside the fridge, there is a coil that is cold instead of hot. A fan must continually blow over that one too, to circulate the air over the cold coils. The fan usually only works when the doors are closed, so be sure to have the door switch pressed to "shut" when checking it.
Check those and post back. And, I know... it really is Dometic.
If the problem is the first one,
Jul 28, 2009 | Dometic RM2620 Refrigerator
Dometic air conditioner not blowing cold air.
make sure fan on auto if ok and unit on cool check compressor coming on if ok bad cooling unit
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
132 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
