Question about Canon PIXMA iP1800 InkJet Photo Printer
Can't put cartridge into printer
Hi Hacked,
I can't put cartridge into canon printer Pixma, iP1800. When I print the cartridge jumps off from the printer.
Please help tell the exact instruction sso that I can print my assigment due this week.
Waiting for your help....
Sincerely,
Luviz
  • 4 more comments
  • Luviz Apr 05, 2008
    Hi oldnovii,
    Can you send me a picture which side of the cartridge is going to fit into it first?
    Thank you for your help.
    Luviz
  • Luviz Apr 06, 2008
    Hi oldnovii
    You are great ! Thank you very much for your effort to help me.
    I have a manual with me that came from the printer but the illustration and the drawing are very bad. The photos are so tiny that I couldn't even see without a magnifying glass. Even with the magnifying glass still not showing which side of the fine cartridge is going to fit it first.
    Thank you very much. . .
    Regards luviz
  • Anonymous May 19, 2008
    CANON MP22O
  • Luviz Jun 20, 2008
    I was such a long time that my problem has been fixed.
    Thank you very much for your service and support. I wish your website will continue helping people. Your team is such an awsome people I can imagine. Credit to you Fix ya!
    Kind regards,
    luviz
  • itsizzy2218 Jul 06, 2008
    I just got a new laptop not too long ago, and I was trying to hook up my Canon PIXMA iP1800 InkJet Photo Printer to my laptop. I installed the hard-drive required for the printer and then I was trying to install the FINE cartridges, but could not understand how to because the pictures were so tiny, and there was only 2 steps, which did not help at all!!
    Here are the 2 steps:
    1. Insert a new FINE Cartridge all the way into the appropriate slot. The Black FINE Cartridge should be installed into the left slot and the Color FINE Cartridge should be installed into the left slot.
    2. Push up the FINE Cartridge until it clicks into place.
    PLEASE HELP ME ASAP!!!
  • spellicot Sep 25, 2008
    i cant put the fine cartridges into the canon ip 1800, i already saw the instructions but i cant! please help me with photos or some thing because i really dont understand thank you so much
  • 667 Answers
If your replacing the fine cartridge follow these steps. Sorry for jumping in but it looks like your in a hurry. If you already solved it, great.
1 Make sure that the printer is on, and then open the Front Cover.
The FINE Cartridge Holder moves to the left.
i_expl.gif Caution Do not hold the FINE Carcan't put cartridge into printer - bullet_s.gifr to stop or move it.
bullet_s.gif can't put cartridge into printer - i_important.gife metallic parts inside the printer.
i_important.gif Important
If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
2 Remove the empty FINE Cartcan't put cartridge into printer - ug_maintenance35.jpgi> Push down the FINE Cartridge.
(2) Remove the FINE Cartrican't put cartridge into printer - i_important.gifmg src="http://i.fixya.net/uploads/images/ug_maintenance35.jpg" acan't put cartridge into printer - bullet_s.gifenance35.jpg" class="h_mi" />
i_important.gif Handle FINE Cartridges carefully to avoid staining your clothes or surrounding work area.
bullet_s.gif Discard empcan't put cartridge into printer - t_01536.jpgtridges according to the local laws and regulations regarding disposal of consumables.
3 Prepare the recan't put cartridge into printer - i_important.gifidge.
(1) Unpack a new FINE Cartridge and remove the can't put cartridge into printer - bullet_s.gifctive tape (A) gently.
*1 To can't put cartridge into printer - bullet_s.giftridge Holder
bullet_s.gif Do not rcan't put cartridge into printer - bullet_s.gif protective tape once you have removed it. Discard it according to the local laws and regulations regarding disposal of consumables.
bullet_s.gif Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE can't put cartridge into printer - ug_maintenance37.jpger may not print out properly if you touch it.
Be careful not to stain your clothes and hands with ink on the removed protective tape.
4 Install the FINE Carcan't put cartridge into printer - ug_maintenance39.jpg/i> Insert a new FINE Cartridge all the way into the appropriate slot. can't put cartridge into printer - i_important.gifck FINE Cartridge should be installed into the left slot (ug_maintenance37.jpg) and the Color FINE Cartridge should be into the right slot (ug_maintenance38.jpg).
(2) Push up the FINE Cartridge until it clicks into place.
The printer cannot be used unless both the FINE Cartridges are installed.
5 Close the Front Cover.
Hope this does it. I'll check on you later. If this fixes you up just rate it a 4 fix ya and I'll know you're ok.
Posted on Mar 28, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Mar 28, 2008
    Sorry about that. I forgot the pictures for you. If you have your manual it's under routine maintainence. If you need one follow this link for an on screen manual. http://www.usa.canon.com/consumer/contro...
    Once tou blick on the manual just click on I AGREE, RUN, RUN. The section you need is under routine naintenance on the left side and then scroll down on the right to replace cartridge. I think you just need to make sure you it seated correctly and iy locks in place.
  • Jeffrey Pemberton
    Jeffrey Pemberton Apr 05, 2008
    What iz luv, Luviz? Sorry about the pictures. But if you read my solution, I added that since I screwed up the pictures, there was a link to download an on-screen manua. This has very good pictures as I have downloaded it myself. I wouldn't give you garbage. It's the same pictures I'dd send you. If you D/L it and istall it, it's simple. Follow the link in my solution. Just scroll down to the manuals section. You want file ip1800osmwin120us.exe Once it's installed and opened, maximize the screen, click on the user's guide bar, then click on Routine Maintenance, Replacing a fine cartridge. The pictures are about two thirds down. Anyway, if you don't have a manual it might be good to get one just so you have. Hope this helps. Even though I've done all this work for you and I get a helpful rating. I kid. Little bit.
Canon ip1800 5 orange flashes then goes green,
The FINE cartridge cannot be
recognized.
Possible causes are as follows:
• The FINE Cartridge may not be installed properly.
• The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output
is not satisfactory, carry out the Print Head Alignment.
Mar 03, 2011 | Canon PIXMA iP1800 Printer
The Cartridge Can't Read
remove the cartridge and clean it with tissue paper and put it back again
Apr 04, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800
Make sure you removed the protective film on the cartridges.I've seen this alot on new installs.Next clean the print catridge contacts with a clean moist (very little) cloth ,then dry cloth.It may work, Good Luck.
Sep 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
New ink cartridge. Canon ip1800 series print is pale
check the settings to insure your aren't printing in "Draft" mode
Jul 23, 2009 | Canon PIXMA iP1800 InkJet Printer
Canon ip1800 printer won't print.
My Canon PIXMA iP1880 cannot print...and shows a message "ink absorber is full" can u help me this problem..
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon printer pixma ip1800 not recognizing new cartridges installed
If the cartridge is new, probably the connector between head and cartridge is dirt. clean it using dry tissue and never touch by hand the metal plate
Mar 10, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Jul 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 printer print cartdidge error
Leave the printer turned on and open the access lid, then reseat the cartridges, and close the lid.
Apr 18, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
1,290 people viewed this question
old marine
old marine
