Question about Panasonic NN-P295SF Microwave Oven
Pushing the start button trips the breaker. All functions seems to work, fan, clock etc but it just started as soon as you push start it trips the breaker. Control panel/board seems fine no burn marks.
  • Panasonic Master
  • 12,061 Answers
Http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Genius/Prestige/model.NN-P295SF
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Service manual below, troubleshoot with that. http://www.eserviceinfo.com/downloadsm/5734/PANASONIC_NN-K652.html
Posted on May 04, 2010
It shut off as soon I push start on my new wave oven
Have you tried in in a different outlet??? Maybe too many things on the same breaker and it tripped??? Most microaves will draw about 12-13 amps, so depending on what size breaker you have it on you may not be able to have anything else on the same circuit.
Sep 28, 2017 | Microwave Ovens
How to reset clock the clock on my KitchenAid Microwave Convection Oven
Usually push click button than set time and push click button again (some will have you push the "start" button)
Feb 03, 2015 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
Apr 14, 2014 | LG LMV1813ST Microwave Oven
Microwave doesn't start but the interior light goes on when you hit the start button
Hello
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Microwave blows fuse
The most common suspects are the high voltage transformer and the magnetron. It's also possible you have a flaky door switch or loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 07, 2007 | Roper MHE14XKB Microwave Oven
Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
Jun 04, 2007 | Sharp R-202EW Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
610 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
