I replaced my PSU and Motherboard due to a lightning strike, now I get a fan failure error after startup. I have checked and my fans are turning. Now what?I replaced my PSU and Motherboard due to a lightning strike, now I get a fan failure error after startup. I have checked and my fans are turning. Now what?
You can't post conmments that contain an email address.
What you should do, go to electronic shop and buy a new fan because sometimes you may loose your motherboad or maybe its the rear fan just purchase a new fan tha'ts the solution nothing else.
how to fix something but but dont touch it>? the is impossible
think that trough?>
most pcs pack in lent every year, its needs service
if not up do doing that your self, try a shop?
the fan must blow and keep the CPU cool or it overheats and fails
the CPU will shut its self down, if it overheats. ending all things..
until its cleaned fully.
google or you tube this. act.
The error message hp laserjet P3005n error 57.03 is due to sub cooling fan (FM2) error has occurred. Fan operation is verified
during device power up. Fan operation occurs only during power up or
during a print job.Turn the device off and then on. Verify that nothing is hindering or blocking the fan.
Verify that the fan is connected to connector J512 on the ECU PCA. You
might have to remove the main cooling fan to see this connection. If the message persists, replace the fan.
The feet may have popped off the bottom, where the vents are located. Either replace the small feet (they just stick on) or set the laptop on a cooling stand so that the bottom is exposed to the air. You may also want to clean the vents.
Please remember to vote for me if you like my solution.
This message means that the fan on your CPU (processor) is failing or has failed. This is not good because if the fan on the CPU fails your CPU will overheat and cause your machine to lock up and become non-functional till it cools down and then the same cycle will repeat till the fan is replaced.
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Check the main cooling fan (fm1) in the rear center of the copier. is it running? if not see if it is plugged in. I had a kid stick a sucker stick in the fan causing the same problem.
