Question about Philips Magnavox 27MS343S 27" TV
Blown up tv (philips)
I work for a small electrical company that had a job with a department store. One of the electricians was in a hurry and did not label his hot and neutral wires for a large area in the electronics section of the store. Someone else connected the wires to the panel which was three phase. Long story short the hot AND the neutral wire feeding the receptacles for a row of LCD TVs ended up both being hot thus sending 208 volts to them. They all blew up. Our company fired the electrician and bought the TVs. They have been sitting in our storage for almost a year. My question to you is- can they be fixed. I wondered if maybe there is a fusable link inside the TVs designed for power surges that took the damage and can be replaced. Are these TVs fit for the garbage can or is there an easy way to fix them? Thank you for your time. Ethan.
  • Philips Master
  • 8,457 Answers
Yes,they can be fix.The problems u discribing to me,like just a big power surge to all the tvs at once.Now just take one by one test it out what wrong with it each one individual tv and fix it that all.Like changing individual componnets or boards parts that all.
Posted on May 04, 2010
    Guru:
  • 513 Answers
There are fuses always inside TVs. The main filters (capacitors) are probably damaged and the regulators are probably blown. Chances are the rest of the set is OK. Sudden bursts like that usually kill the fuses very fast and the regulator takes the brunt of the load. With a multimeter, you could probably check regulators for shorts and replace fuses.
Hello my electric trips in conservatory I unplugged all sockets,and still trips cable comes from circuit box runs outside wall to conservatory in wall to first socket
Sounds as though the wire has corroded or from heat/cold damage crumbled the inside wire coating creating a short circuit, you will have to call a qualified electrician to rectify this, as an unqualified person correcting it can invalidate your house insurance cover, in the event of damage caused from an unqualified worker, I would turn off the switch for that wire at circuit board & leave it until you can call an electrician in after the festive period, I say this only because you could end up paying premium rate for the job to be completed, please check that you contact reputable trader/electrician through somewhere like check'a'trade or google reviews for good companies in your area, please get several quotes before accepting the work to be completed, so you can get a honest & good genuine company, always ask to see credentials & electrical qualifications cards before hand, Hope this helps ????
Dec 30, 2017 | Dryers
Rear projection tv coolent replacement
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace.
Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs.
You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet.
In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer.
All can be replaced at a local electronic or hardware store and they're easy to replace
If this does not correct the problem, you may need to have your TV serviced.
good luck!
Dec 01, 2007 | Televison & Video
How to find a good electrion
Hi Gladys,
I'm an electrician and would like to help you out. You should contact your friends and nieghbors to learn of the experiences they have had - both good and bad - with electricians.
Ideally, the work they had done was similir to the work you need to have done for a good "apples to apples - oranges to oranges" comparison. Next, you can contact your community's Better Business Bureau. Their recommendation is only for companies that have PAID them to be listed - however - they will tell you how many complaints, etc. they have had with the ones you ask about - so a "recommendation" from them really has little to do with the quality of the work the company performs.
Angie's List is an online data base of all kinds of service providers that many people swear by. It does cost to join however, so if your project is only a repair or small job, it may not be the best way to go.
Yelp is a free version of Angie's List (but it is NOT affiliated with Angie's List - just to be clear). Here, you'll find ratings from antone that cares to write a review on a business - from Pizza Joints to Dentists.
With these sources, you should be able to get a fairly good idea of the reputation of the electricans in your area. I hope this helps & good luck!
Mar 01, 2013 | Electric Electrical Supplies
I want too lear too instal current at home,ect
Becoming an Apprentice Electrician, and/or moving on to a Journeyman, then Master Electrician, involves either going to a Vocational Technical, (VoTech), school, or learning on the job.
As you work on the job, you will be under the license of an electrician. After you learn your craft to an extent, you can take a test for becoming an Apprentice Electrician. Then after two years on the job you ca test out for your Journeymans Electrician license. You will be tested in the Residential, and Commercial areas.
See if there is a company that is willing to hire someone, who wants to learn the Electricians craft in your area.
Tips from me:
1.When working on a circuit, NEVER assume the power is off. Even when you are sure it is.
Use your test equipment, and make a quick check before you put your hands in there!
Has kept me from getting shocked for many years now.
2.After making a wire connection to the breaker, before you insert the breaker in the Service Panel, wiggle the wire a little. Then try to tighten down the circuit breaker screw, a little more. You're dealing with Alternating Current, (AC), and AC vibrates! It can eventually vibrate screws loose! (50 to 60 Hertz. Hertz means Cycles per Second)
Jul 18, 2009 | General Electric 20 Amp, 1 Pole Thick Type...
My tv don't work
open the small hatch next to where the power cord enters the back of your t.v. using a phillips screwd you driver. There is a small fuse there that may be blown//careful not to touch anything and remember that even if the unit is unplugged their are circuits inside that will still store a high voltage charge.
Feb 03, 2007 | Philips Magnavox 20MC4304 20 in....
Philips Magnavox 27MS343S 27" TV Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
