Question about IBM NetVista PC Desktop
I dont have 2.0 usb how can i update my present usb controller
    President:
  • 1,070 Answers
Dear Friend,
You can identify whether your PC has Hi-Speed USB or not relatively
easy. Open Device Manager and expand the Universal Serial Bus section. There should be an "Enhanced" USB host controller present.
There are currently 7 manufacturers of the Hi-Speed USB host silicon themselves:ALi (Acer Labs), Intel, NEC, Sis, VIA, NVIDIA (shows as "Standard" controller),Philips.
Note:Older computers may have only the slower USB 1.1 interface. Adding USB 2.0 isn't difficult, but it does require a hardware addition.
There is no need to Update your USB in Latest PC.
You have to do one thing is that ensure you are perfectly Installed your Drivers(Included in CD which you Owned when Purchasing PC).
I hope You made it clear ...Thanks for Contacting FixYa...
Posted on May 04, 2010
    Novelist:
  • 138 Answers
Hello
Unfortunately, you cannot update the motherboard USB controller to the 2.0 USB standard.
The easiest way to make a computer USB 2.0 compliant is to install a USB 2.0 PCI card in it. Most USB cards have an internal USB port so you can connect the USB slots on the front of the PC to the new USB 2.0 card.
Toshiba BDX5400KC, firmware version 0.60. Cannot update firmware because the Linux front end file is not present in the update from Toshiba's website. I went as far as formatting the USB drive in FAT32...
WHOA!, what ever you do,DONT PLUG IN COM 2COM without the right cord! I also had a question about connecting from one com to another via usb cord. I found out that it takes a special cord to do that. the cord in question has a little box it one side of the plug just for com 2 com/usb connections. It will literally MELT the plain usb cord and blow out the socket!! probably destroying both computers. Sorry, i cant help you on your problem, but i DO know about the usb thing. GOOD LUCK!!
Nov 05, 2013 | Toshiba Televison & Video
USB DONT WORK
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Mar 12, 2013 | Compaq Computers & Internet
Toshiba external hard drive not detected
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
Windows 7
Some external storage devices work poorly or not at all when connected to a hub; try connecting the drive directly to a port on the computer.
Also check if it's detected in "Disk Management".
Here you can verify if the partition and format are correct for the Operating System.
Check the Drive's status in Device manager.
This will verify if the external drive has a drive letter designation.
Check Partition and Format.
Log in as Administrator account in windows or any other account with administrative privileges
Insert your removable disk into the USB port.
Click Start, right click on computer and select manage.
Now, click Disk Management.
Check whether drive letter for the device is present.
Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc).
If the device is detected with a drive letter, verify that no other device is using that drive letter.
If it is, change it to unused drive letter.
if you dont have a disk with the drivers
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Sep 18, 2012 | Toshiba 10TB USB 30 Desktop External 1 TB...
WD28001032 DRIVER
hope this helps
Mar 13, 2012 | Western Digital 250GB MyBook External USB...
Usb port dont work
First check in device manager about USB controller status if its not yellow mark then or not present check in the bios about hardware is disabled or not present at last if anything not works you have to replace your usb controller if its onboard then get additional from market and fix in the PCI socket
Nov 11, 2011 | HP G70-250us Notebook
I an not have driver usb for hdd2193 for fix problem
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports(com&lpt)right click update driver if this fails to fix the problem
if you dont have a motherboard disk you will need to download the drivers
Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
hope this helps you
Sep 11, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
When i have switch on the phone the display is showing white screen so what is the problem can u give a solution
This problem is due to software problem or due to a virus
there r 2 solutions for this problem....
1. Update ur mobile software using the latest Nokia Software Updater present in Nokia PC Suit (update).
This is ur own risk. U should have a stable internet connection and the full charging of ur mobile battery as if ur mobile update is interrupted, ur phone no longer works. So Be Careful.
2. Simple go to ur nearest nokia care center and give Rs.300/- if u dont have warrent and get ur mobile updated. If u have warrenty, it is free .
CAUTION: BEFORE UPDATING OR TAKING TO THE NOKIA CARE, PLEASE BACK UP UR DATA PRESENT IN THE PHONE MEMORY. BECAUSE ONCE UPDATE STARTED, UR DATA WILL BE LOST PERMINENTLY.....
ENJOY UPDATE!!!
Nov 15, 2010 | Nokia 7210
Pmy mobigh memoryli super nova 7210 phone music player is not working ..problem is not enough memory
ENJOY UPDATE!!!
Nov 12, 2010 | Nokia 7210
My phone is stuck on "Nokia" that comes on starting up.
It may be due to software problem or due to a virus
ENJOY UPDATE!!!
Usb 2.0
Yes, your M2V board is USB 2.0 complaint.
How do know if your PC has USB 2.0?
You can identify whether your PC has Hi-Speed USB or relatively easy. Open control panel, open System. Click the Hardware tab & Click Device Manager.
Scroll down to Universal Serial Bus Controllers. Click the + sign to expand. There should be an "Enhanced" USB host controller present. Windows 98 systems may use a different name, because Hi-Speed USB drivers in this operating systems are not provided directly from Microsoft, (Windows ME, 2000 and XP)
get their drivers through (Windows Update). There should also be two "standard" version USB host controllers present as well. They are embedded in the USB chip which routes the differing
USB speeds accordingly without user intervention. nVidia (shows as "Standard" controller) & not enhanced but are still USB 2.0
You need to enter your bios. How to enter your bios?
When you turn on your Pc press the delete key every 2 or 3 seconds. Your system will load the bios. Use your manual & go to pg. 4-16 section 4.4.2. Make sure you have Enabled USB 1.1 & enable USB 2.0. Enable Legacy USB support & set USB 2.0 Controller Mode to HiSpeed. Bios EHCI Hand-off, set to Enable
Save & Exit your bios. When your system has finished loading run Windows Update. This will update your USB driver to 2.0
How fast is USB 2.0? USB 2.0 has a raw data rate at 480Mbps.
If you have more question just ask!
please vote...
Feb 12, 2008 | ASUS M2V Motherboard
IBM NetVista PC Desktop Logo
407 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
