Question about Canon MV800i Mini DV Digital Camcorder
I have the same problem but nothing has worked! There's a bit of a burnt smell inside the unit but it powers up ok - well to the point of the annoying 'eject' sounds, and the more frustrating problem of it not ejecting.
    Guru:
  • 513 Answers
This is commonly a 'capstan motor' the part that drives the tape. This causes no eject, sometimes a burnt smell and blown internal fuses.
The motor needs replacing, possibly a fuse and a check for why it has a burnt smell.
Posted on May 04, 2010
Testimonial: "Awesome. Thank you."
Burnt wire smell Board Flashing Br
The unit was running when we came in. No Storms in the area. it was blowing hot air, but was still on the cool setting. There was a burnt wire smell coming from the unit. And the diag. code was Br. I found this odd since it still had power.
Aug 16, 2014 | Amana PTH153B50AM Air Conditioner
I have a Jensen JCD2010 in my travel trailer. There is power to the unit, but there is no display. Nothing happens when I push the buttons and dials. The display is blank. Could it be that it is due to me...
It should have two power inputs.
One is connected to the battery, uses very little power to maintain presets, maybe an LED also. The other is via ignition switch.
My Jensen 2620 requires both inputs to function.
May 27, 2014 | Jensen JCD2010 AM/FM/CD Stereo
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
Motor overheats and stops. Battery loses half of power in 100 yards. Have sought repairs for unit since 2008 will not replace parts.
Hi. Sounds a bit like the motor has a short circuit in the armature. How old is the machine? How old are the batteries?
Remove one or both of the brushes, and try to smell the inside of the motor. A burnt out motor will have a strong smell of burnt varnish.
Is the machine still under warranty?
Another cause could be a seized or binding brake assembly. With the free-wheel lever released, can you easily push the machine along the ground?
Good luck. Neil.
Jul 03, 2010 | Drive Medical Odyssey 4-Wheel Power...
Last night my wife accidently turned on the microwave with nothing inside. It probably ran for 15-20 minutes before I noticed a burning smell (burnt wiring) After opening the door I noticed the unit had no...
well I can tell you roughly what happened. You overheated the oven, as there was nothing inside to absorb the radiation. So the sensor shout off the power ( safety switch) It returns when the oven reduces in temperature. The burning may be due to internal damage to some of the insulation compound. It takes foreverf to get rid of smells from microwaves no matter what you use including vanill or some other anti stink medicine. The unit is probably OK but overtime will now begin to deteriorate and may even leak radiation to greater extent.
Dump it is my suggestion, but make sure it is damaged sufficiently to prevent dump rats from salvaging it and using it.
The unusual noise ( almost missed that) is damage to the rotation motor bearins that have been expanded and are now out of alignment.
Too risky!
Jul 31, 2009 | Microwave Ovens
Duo Therm 57915.541
Since you have a knob, I am assuming that this unit has manual controls that are mounted directly below the air conditioner on a ceiling pack. If you smell burned wiring, remove the inside shroud to access the 120VAC connections in the unit. Check these connections for OK, if they look burnt, cut them back and reattach them (be sure to turn the breaker off first). Try the AC again.
If those connections look fine, then remove the upper cover from the unit. Access the capacitors on the side of the unit and check them for ok. If any one of them looks burnt, replace it. These two places are usually the only place that you will get a burned plastic smell.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Stopped working smells like something burned?
If this is a ducted unit with a wall mount thermostat, remove the inside cover from the AC unit. There is a silver box with the electronics inside. Remove this box and remove the cover. Visually inspect the connections where the 120VAC connects. If that looks ok, then check the relays on the printed circuit board. If these look burnt, replace the control box. If they look ok, check to see if there is power coming in to the unit. If not, check the breakers and make sure they are ok.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Burnt Rubber Smell
ok the rubber smell is your socks and underwear band,,and things with elastic in them ...ok open your dryer ,,look in the back where the hot air blows out,,,does it look like a burned iron..that where the clothe stick and melt too..just take a brillo with a little bit of water,,little dampness ans scrub the area..onthejob...
Feb 02, 2009 | Whirlpool LER7646E Dryer
No power in multimedia projector
is the lamp burnt out?
try it in another outlet?
smell the unit and see if anything smell burnt.
it could be the power supply in the unit as well causeing the issue if non of the leds are displaying as well. make sure all connections are tight as well.
hope this helps a bit.
Aug 02, 2008 | 3M MP 7740i Multimedia Projector
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Canon MV800i Mini DV Digital Camcorder Logo
250 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
