Question about Troy-Bilt Pony Garden Tiller
Can not get tines off shaft - Troy-Bilt Pony Garden Tiller
    Sniper:
  • 53 Answers
Ya you have to do that properly. Get the blow up diagram. but usually there are clevis pins that must be removed. I have a 11Hp Craftsman rear tine. Those tines are removed easy with clevis pins.
Posted on May 06, 2010
How do I change the tines
You have not shared which model and make of tiller you have, but many of them have a set screw or two holding each tine on.
You would need to loosen the screws, and maybe polish the shaft with sandpaper and oil it to get each tine off in order.
Some tillers use a different method of tine installation, since this can be patented or trademarked.
For example, some have the tines permanently attached to the shaft, so the whole shaft must be replaced as a unit.
God bless your efforts.
May 12, 2016 | Garden
Leaking tine shaft
your seal on the shaft defective,
www.ask.com/mfg.name/make/model/service/parts/leaking/tine/shaft/
Oct 02, 2015 | Troy-Bilt Troybilt Horse 6, 7 And 8 Hp...
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
I need to replace the seals on my Troy-Built Pony tiller. 6 hp, ser.# 121811201149. I can not seem to remove the tine shafts. I have pulled the bolt thru the shaft but cannot budge it. Does anyone know...
I presume you opened the port and removed the grade 8 placement bolt? If you have then you need to polish the shafts with 400 then 800 sandpaper, clean then lube them before trying to slide thru the support bearings. If your tine shaft is bent? your screwed, or just remove the shaft seals with a screwdriver and replacing them without removing the shaft. REmember to put a thin coat od RTV arround the outer lip to help make a better seal
Nov 15, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Put it in gear and as soon as it has a load it stops tines and wheels. Has trans grease, and have tried to tighten belt by the two side adjustments but it will not move? It is an older tiller Kohler engine...
It sounds like the key that holds the pulley on the front of the tiller transfer case has sheared into. Carefully remove the belt safety cover so the belts are exposed and start the tiller. With a flashlight look at the pully on the lower shaft and shaft area. Carefully engage the tines and see it they are turning. With a second person visually, from the side, inspect the pulleys to make sure they are turning. Now carefully load the tines and see if the pullies of shaft stop turning. If the shaft stops and the pulleys keep turning then the key on the shaft has sheared off. If both keep turning then you have something that has broken or sheered in the transfer case. This type of inspection is dangerous and needs to be done at a distance with a flashlight so you can see down in the shaft area when standing off to the side while someone loads the tines. It is very difficult to try and see if the shaft is sheered in the pully as is the case without the engine running. The key has friction and it is difficult to turn the tines with the drive engaged to the engine. The only other option is to disassemble the transfer case to see what has gone bad. Please be careful testing it. Good Luck, RAC
Mar 07, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
137 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
