Question about Sylvania Televison & Video
When I push the on button the green light flashes and the unit turns itself off after about 2 seconds. This happened just recently. I pushed the on button on the side of the unit, heard a little sizzle and it went off. model #LC320SS8A serial # J6073727
  • robertandbor May 04, 2010
    thanks, nettiser.
    now my problem is finding a repair place nearby
    Brigadier General:
  • 4,090 Answers
The little sizzle is the worry!
Capacitors on the power board have burned out. Sylvania are not cheap to repair
It is not a DIY as the problem may go beyond the power board itself. Because the little green light is on does not mean it can still have power to it. the green light is on the wall side of the Power supply The bits you want to work arfe on the other side of that contril board and are now short circuited.
Best to have it looked at by a pro as it will end up like others who tried to short ciut the $.. and found it cost more $ than they thought they would save by an attempted DIY.
Please rate my help++++Thyanks for using FIXYA
Posted on May 04, 2010
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    I have a Denon 1708 receiver. When I push the "on" button, either on the unit itself or using the remote, the light flashes green for a few seconds, then flashes red. When it turns red, all of the info...
    Your result indicates the unit is not passing its power up self test. The first thing to try would be to remove all connections to the unit and try to power up. If it still mis-behaves, the unit has an internal problem best left to pros unless you're pretty good digging through circuitry. If it comes up stable, then reconnect things one at a time until the issue occurs again. Detach the offending connection and look for issues in the cables or the connected unit.
    Oct 23, 2010 | Denon AVR-1708 Receiver
    TV won't turn on...after hitting the power button, the light turn green for about 3 seconds, then turns red and the screen never come on. Pressing the power button again turns the whole thing off (no...
    It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
    You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
    Jan 22, 2010 | NEC PlasmaSync 42MP2 42 in. Television
    2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
    Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
    Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
    Remote not workin
    what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
    THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
    · Any of the system components (room unit or relay box) are replaced
    · HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
    · Interference with the RF signal has caused a communication failure
    During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
    1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
    2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
    3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
    4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
    5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
    hope this is helpful
    Feb 15, 2009 | Honeywell Programmable Thermostat Heater
    Dell XPS 200
    Is the amber light blinking? Indicates PS not operating within specs. You can look at replacing the PS (~$79-99). GL
    Aug 09, 2008 | Dell XPS 200 PC Desktop
    Filter light still on "Red"
    try holding ice type and child lock together for 3 seconds that worked on mine
    Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
    Televison & Video Logo
    46 people viewed this question
    Top Sylvania Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
