Question about Freezers
-40 F Freezer
How to modify my freezer to -40F? Please help me.
    Novelist:
  • 184 Answers
MINUS FORTY DEGREES IS TOO EXTREME FOR A FOOD FREEZER. IF YOU ARE GOING TO USE IT FOR SOMETHING ELSE, YOU WILL PROBABLY HAVE TO REPLACE THE CONTROL WITH SOMETHING ELSE. MOST STANDARD FREEZER CONTROLS ARE DESIGNED FOR TEMPS BETWEEN -10 AND +10 DEGREES FAHRENHEIT.
Posted on Apr 05, 2008
SOURCE:
The freezer won't keep normal -10F temperature, but stays at -35F to -40F at all times
Thermostat or start relay is defective and causing the compressor and fans to run all the time. Here is a manual for all models=> HERE
Sea Breerze
Feb 10, 2013 | True 49 cu. ft. / 1388 liter Commercial...
Can a delfield model 407 using r12 freon be modified with a new compressor to use current refrigerants
yes it can. if the model is a techumseh find the local dealer.
give them the compressor model # and get the new 134a model
equivelant. no oil change . replace the filter drier when you replace it .the refrigerant charge will be about 90% of the original r-12 charge
Nov 08, 2012 | Delfield Freezers
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
Sanyo Frost Free Fridge (Model SR 1031) very slow to cycle through freeze to defrost back to freeze cycle. The temp in Freezer compartment goes from -17 degrees to -1 degree then back to -17 as it takes in...
DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
Feb 10, 2010 | Freezers
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
How to remove drain pan from compressor
the drain pan removal requires a sealed system repair to modify the type and new location of the replacement drain pan. this should get repaired by a certified refrigeration service technician.
Sep 18, 2017 | Kenmore Freezers
I wolud like to modify my Kenmore chest freezer to -40F.
the amount of coolant is not the issue, its strictly a thermostat issue,WOW -40 though i dont know where youd geta thermo to go that low. def not in ANY residential/local appliance outlet
Mar 23, 2008 | Freezers
Freezers Logo
78 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
