Question about Lexmark X3350 All-In-One InkJet Printer
The power light blinks, nothing works after changing color cartri
Message says carrier jam. How do I fix
  • 4,041 Answers
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 04, 2010
Hi im having some problems my aunt just gave me her lexmark 1250 and the paper keeps jamming i think i have that fixed but now i go to print a test page to see if its working and all i get is a flashing...
The flashing power light could be to a faulty cartridge or the cartridge carrier has stalled. Follow the steps below to fix the problem:
  1. Open the printer cover.
  2. Ensure there is no jammed paper in the cartridge area and the cartridge carrier is free from any obstructions (any foreign objects or debris)
  3. Remove both cartridges from the printer.
  4. Close the printer cover.
  5. Unplug and replug the printer into the power source to reset it.
  6. When the printer turns on, re-insert 1 cartridge first. Close the printer cover.
  7. Check the light pattern on the power. If not blinking, open the printer cover and re-insert the other cartridge.
  8. Replace whichever cartridge is causing the power light to blink.
Hope this information has been helpful.
Jul 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
All the paper and color lights blink at once?
Turn it off then back on...if that doesnt help you probably have either a paper jam or a stuck cartridge carrier.
Check the paper path and if its clear, gently try to move the cartidge carrier one way or the other with the power off, then turn power back on and see if it is fixed.
Nov 07, 2009 | Epson Stylus C86 InkJet Printer
Lights are flashing on printer and it will not print . the voice says there is a problem with the printer. I did the alignment process but the voice keeps saying there is a problem. I took both cartridges...
There 3 light on the printer that able to indicate to user when problem occur. Which is the light u mean here?
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Sep 28, 2009 | Lexmark X2500 All-In-One Printer
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Dell 924 dell printer head ;error 1203;change cartri... sane problem.help|| black will print but color wont print' correct cartridge is inserted ,still color wont print. warning was ignore that ink was low
Hey do a power drain by removing all the cables from the rear of the printer and then hold the power button on the printer of 15-20seconds with all the cable out connecting the printer... Then power on the printer if you still see the error code message displayed on the printer display screen do a nozzle clean in the computer, check on if the printer prints the nozzle clean test page perfectly.If not remove the cartridges and clean the nozzle of the cartridges with a clean cloth and be careful so that you do not destroy the copper contacts, clean the same you see on the carrier(where you place on the cartridges). I think this should work.
If not call in technical support.
Regards,
Dev,
Printer Technician.
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Carrier Jam
The top of my ink cartridge had fallen off and was in the printer... I hadn't seen any paper or anything and was completely stumped, when I picked it up and heard something in there... It was hard to get back on, but now it works!
Jan 08, 2008 | Dell 924 All-in-One InkJet Printer
Carrier jam
i had the same problem and i'm almost positive it's because i do not have a color ink cartridge in my printer. i called the technical support and they said that both ink cartridges have to be in the carrier for the printer to work. even if one of them does not have ink in it. hope this helps. (for me too)
Dec 18, 2007 | Dell 924 All-in-One InkJet Printer
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark X3350 All-In-One InkJet Printer Logo
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
