Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My magnavox model is 9p6040 c102. the problem i have is poor picture quality and picture blinks from large to small. I think the sound goes in and out during the time the picture is blinking. do you think should let this tv rst in peace or can it be reasoable repaired.
  • Philips Master
  • 8,457 Answers
Ur tv convergence ICS are dying.This problems,the shop should cost u about $300-350 for parts and labors
Posted on May 04, 2010
Poor picture quality. Picture also tends to curve
The curving is caused by bad digital convergencr chips (2) located on large signal board. They need replaced along with blown pico fuses and the convergence resistors. Chips are huge compared to a regular IC. 2" x 1.5" and they will be bolted on fairly large heatsinks. Cloudy picture is most likely the coolant needs replaced in the picture tubes. This needs to be done approximately every 5 years.
May 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
Picture is going out
it is either ic 7411,7412, 7413 they are cheap replace all three, they are located on the back of the large signal panel right in the middle, very common issue. If you can't solder the repair may cost around 200 or so .
Sep 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have aMagnavox 9P6040 C104.The picture is extremely poor.
The problem is the fluid in the Blue and Green CRT's needs replaced. ( ethylene glycol ) It not something you should attempt if you've never done one. The average price with most shops is around $250.00, and your other concern, there is no auto convergence on that model. It's all done by remote in your menu and in the service mode, but that's not your issue, just get the fluid replaced and your back in business. Have a nice Holiday Weekend.
May 23, 2009 | Philips Televison & Video
Picture shrinks and expands
Not positive but this sounds like the impending failure of a specific power supply, namely an output providing deflection voltage to the CRTs. This may be simply a circuit on the main supply or could be a separate supply on a different board than the main supply.
If it is not affecting brightness and contrast, it isn't likely to be the primary supply that is failing. I'm pretty sure it will continue to degrade.
Oct 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 9p6040
Sounds like a solder or connection issue on the small signal panel. which is the ciruit baord on the left hand side of the set looking in from the rear of the set.
Jun 13, 2008 | Philips Magnavox 9P6034C 60" Rear...
9p6040 c102
Visit www.TvRepairKit.com for a repair kit. Its a common problem and an easy fix.
Jan 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9p6040 c102
IC's on convergence bd. 1st try opto coupler philips part# 483520988561 actual part# to buy HCNW136 some replace all 3 IC's philips# 483520987834 actual# MC34065p and philips# 483520987712 actual# SC78104 search google to buy.Datasheets at datasheetcatolog.com
Nov 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
148 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
