Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
-40 F Freezer
How to modify my freezer to -40F? Please help me.
  • 1 more comment
  • Kasem Mar 26, 2008
    Where can I buy this thermostat? And there is any problems with a thermostat when it runs continuously. Thanks
    Sorry. Are there any problems with a compressor when it runs continuously. Thanks
  • Kasem Mar 28, 2008
    Thank You very much.
    Have a good day.
Running continuously will certainly shorten the compressor life dramatically not the thermostat life.There are no moving parts in the thermostat. A good refridgerator will run for over 15 years under normal operation (cycling on and off). Running continuously is a **** shoot. depending on well it was made. How well the refridgerator is insulated will also help. If the insulation is not the best or insufficient in thickness etc the freezer may never get to -40. Keep the evaporator coils clean and well ventilated.
An appliance repair or parts supply place should be able to sell you a thermostat. Look in the yellow pages.
Posted on Mar 27, 2008
Change out the temperature controller ie thermostat with one that will go to -40 degrees. This will be very ******* the compressor and may even cause the comporessor to run continuously and that's not what they are designed to do.
Posted on Mar 26, 2008
SOURCE:
Sears top freezer uneven temps
Check damper between Fridge and freezer. Set it to move more air to Fridge.
Sep 27, 2017 | Sears Refrigerators
What should the temperature be set on for a
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Aug 30, 2014 | Kenmore Refrigerators
Freezer is at 20F
The louvre that let's the air into the freezer is probably closed nearly ll the way shut, thus not allowing the cold air in. The same compressor runs the frig and freezer. Find where the air is coming in and there is where you should find your problem.
Feb 03, 2013 | Amana Refrigerators
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
What are the factory suggested settings?
Half way between off and the coldest setting on the t-stat.
Your refrigerator should be from 36f-40f and the freezer should be around 5f-10f. I hope this helps you. Please leave feedback.
Thank you.
Aug 24, 2010 | LG 24.7 Cu. Ft. Side-by-Side Refrigerator...
What are the correct temps. for freezer and main refrigerator
Refrigerator should not be warmer than 40F. Optimal temps are 34F, this keeps your food cold without freezing it and slows down bacteria growth !
Freezer section no warmer than 10F. Normal temp 0F, optimal/recommended -10F (also for cold icecream) and for quick recovery in case of power outages.
I hope this helps.
Sep 25, 2009 | Frigidaire Refrigerators
-40 F Freezer
MINUS FORTY DEGREES IS TOO EXTREME FOR A FOOD FREEZER. IF YOU ARE GOING TO USE IT FOR SOMETHING ELSE, YOU WILL PROBABLY HAVE TO REPLACE THE CONTROL WITH SOMETHING ELSE. MOST STANDARD FREEZER CONTROLS ARE DESIGNED FOR TEMPS BETWEEN -10 AND +10 DEGREES FAHRENHEIT.
Mar 26, 2008 | Freezers
I wolud like to modify my Kenmore chest freezer to -40F.
the amount of coolant is not the issue, its strictly a thermostat issue,WOW -40 though i dont know where youd geta thermo to go that low. def not in ANY residential/local appliance outlet
Mar 23, 2008 | Freezers
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
100 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
