Question about Samsung Refrigerators
Replacing water line up freezer door - Samsung Refrigerators
  • jjjtlauderba May 04, 2010
    samsung rs2533sw. The line was broken right at the bottom of the door where it cannot be spliced. I am trying to figure out how to do this.
    yes broke eright at bottom of door
    Genius:
  • 1,040 Answers
Dear jjjtlauderba,
The best way is to search for service manual of your gadget. There you will get exact information about the same.... for this following link may help you... http://www.givemefile.net/smanuals-page.html
On some refrigerators the door will come apart but some refrigerators such as newer GE refrigerators the door will not come apart.
If you have a door that will not come apart you will have to replace the door unless you can feed a new line up there somehow. This may work: take a screw and screw it into the old line then cut the head off the screw and twist the new line onto the screw so that you can pull the new line in as you pull the old line out.
The “official” way to repair this would be to replace the door but if you can get the line through the door it should work.
Posted on May 04, 2010
  • 787 Answers
So it broke in a place where you can't take it out to fix it?
  • 2,335 Answers
I would be happy to help you with your refrigerator water line.
Please post the model of your Samsung refrigerator.
This will help us find model specific information regarding accessing and replacing your fridge parts.
Water dispenser does not work, any time it is used water just drains out of bottom of freezer area onto floor. Ice cubes works
Hello Melissa;
My name is Peter. I am a retired field service refrigeration technician.
I am sorry to say you have a serious problem.
The water supply line to your ice maker runs up the back of your refrigerator from the ice maker solenoid. It is a separate water supply line.
Your water dispenser water line runs from the water dispenser solenoid under your unit and up from the bottom of you freeze door.
You have a plastic tubing leak within your freezer door. Calling a service company to replace the freezer door tubing - a good service technician would not replace the tubing - the damage has already been done.
The insulating material in your freezer door is soaked. The water in the door will cause the door liner to expand and crack. There is no way to completely dry out the insulating material.
The only fix is to replace the freezer door. So, $300.00+ for the door and $150.00+ for the service tech. No, a hair dryer will not do it.
May I suggest:
1.) Remove the bottom toe plate (Kicker plate) in the front of your refrigerator.
2.) Turn the leveling screws counter clockwise so you can pull the refrigerator out to get behind it.
3.) Unplug the unit.
4.) Remove the screws from the bottom cover.
5.) There are two connectors to the solenoid valve to the water dispenser. It is the larger diameter tubing running under your refrigerator.
This will disable your water dispenser. If you see cracks on the inside of your freezer door, seal them with a high temperature silicone adhesive.
If you elect to purchase a new unit, check out Sears Outlet (Scratch & Dent) Stores.
May 08, 2015 | Refrigerators
The water dispense not work ice is good.
Check water line from bottom of freezer door open line if you have water there when activating water arm then you have frozzen water line in door common GE problem need heat strip added in side door GE has a kit for that
if there is no water at door then replace water valve in back of ref bottom under cover freezer side
Jan 30, 2013 | Refrigerators
While water is being dispensed through the cool water outlet, water leaks thru the flexable line at the bottom of the freezer compartment door. Whats the problem, and how can it be fixed?
Due to water comming from the bottom of the dooe , you will need to replace the door water line . Pt # WR17X10206 is the replacement line . Remove the upper portion and " feed " the new line down thru the freezer door .
May 30, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker works fine but no water at door. Have water at bottom of door at quick connect but not at dispenser.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . There is also , a dispenser heater , pt . # WR49X10173 , which comes with instructions , to keep this grom happening again .
Nov 26, 2009 | Hotpoint HSS25GFP Side by Side...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispensor quit working
the water line that runs from the bottom of the freezer door up to the water dispenser is probably frozen. I have run across this problem several times. you can take the line out of the freezer door, thaw it out and re-insert it, but chances are it will happen again. usually when you have that issue, there is a problem with the insulation in the freezer door and you will need to have the whole freezer door replaced. Joe
Dec 03, 2008 | Whirlpool GS6SHEXNS Side by Side...
Water supply line
If you want to replace just the water line going inside the door, you are out of luck. The water line is foamed in place inside the door and is not replaceable without replacing the entire freezer door. If you want to just remove the door, the water line disconnects by pushing the collar on the insta-push fitting toward the center of the fitting while pulling on the tube, all of which is located behind the toe kick plate near the bottom hinge of the freezer door. The same door is used on the PSS26MRSASS, PSS26MRSCSS, PSS26MRSDSS, and the PSS26MRSESS. It is part # WR78X11742 and runs about $500. (note: even if you don't like what you just read, accurate info on your repair question deserves a "FixYa" rating, not just a "helpful" or "tanks for trying".)
Sep 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
the problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Apr 10, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
