Question about GE Spacemaker JVM1640SJ Microwave Oven
We had a powersurge and now there is no power to the unit
EMERSON MWG9115SL-D WILL NOT POWER UP
Hello, welcome to Fixya!
The unit not powering up is an indication that it has a power fault.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 22, 2011 | Microwave Ovens
No power. outlet is good, microwave plugged in. no lights, no power, nothing. does this unit have a power supply that might have gone bad?
the problem of this unit is power related.
Regards.
Nov 06, 2011 | Hotpoint RVM1435 Microwave Oven
My sharp grill2convection made a noise and quite working. is this possibly a fuse?
Regards.
Nov 06, 2011 | Sharp R-930AK Convection/Microwave Oven
No power to microwave outlet funtioning properly
Best wishes.
Nov 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker light blew and now wont turn on
Regards.
Ge spacemaker jvm1650sh01 has no power after power outage
Regards.
Nov 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a samsung microwave that my daughter ran 20 min. empty. now nothing works. it acts like there is no power, but have checked my breakers and tried various plus. stiill nothing. what does the fuse or...
Best wishes.
Oct 21, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Motherboard problem in a KEMI300wbl3.After a powersurge the clock will set and the oven timer will work but the keypad resets to 0000 when I press start
There are electrolytic filter capacitors on the control board which, due to age, can weaken, causing some bizarre results.
We've repaired several of these boards successfully, upgrading the capacitors and relays at the same time. It runs $39.95 and comes with a one-year guarantee.
They're the same as the Whirlpool RM286- and RM288-type models.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded views here.
Oct 08, 2011 | KitchenAid KEMC377K Convection / Microwave...
Our panasonic Microwave/convection is totally non-responsive--no lights, no sounds, etc.
Regards.
Walesarumi
Sep 29, 2011 | Panasonic NN-T888S Convection/Microwave...
Whole unit will not show power... OUtlet shows power so unit has power... Are there any fuses in the unit? Would they power down the whole unit if they were blown?
Ok....first you don't have a model or make, but yes there should be use, sometimes replacable, inside, if it blows because purhaps the unit was ran empty, it would power off the whole unit, i had a unit that would shut itself off during cooking, and never come back on for days, this was a problem witht the power supply of the circuit board, if you have no worries, purhaps bang on the side, with out denting it, and see if it comes back on, if it does don t use it.
Jun 19, 2010 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
20 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
