Question about Nintendo DS Lite Console
Nintendo DS Adapter
I have just bought a Nintendo DS lite from the states. The adapter does not work in India despite using an Indian power pin. I have tried numerous brands but none seem to get the orange light on for charging the gizmo.
Please help!
  • nani9 Mar 09, 2009
    Please help!
    Naveen Anumala
    Sergeant:
    Champion:
  • 250 Answers
You'll need an adapter that works in your country. If once you have that it still does not work then you probably need a new battery. Without a working battery you won't be able to play the DS even if the charger is plugged in. The charging light will flash and go out if the battery is bad.
Posted on Mar 29, 2008
What is the actual price of nintendo ds lite in indian curency
$0.0226 = 1 Indian rupee
PRICE OF NINTENDO = $120
SO THE PRICE IN INDIA IS 5311.1916
PLEASE RATE IF THIS HELPED YOU
Apr 11, 2011 | Nintendo DS Lite
Nintendo DS will not Charge. The light comes on for about 5 seconds then cuts off
Hi.
Check the power from power adapter using a multimeter. The power supply must have 5V and may have a difference up to 0.5V.
If the adapter is OK, then replace the battery.
Regards.
G.
Oct 05, 2010 | Nintendo DS Lite Console
On power up the green light is on for 2 sec.
problem with the main board inside of the DS Lite. Its not staying on with the voltage being provided. To verify this. Plug your DS Lite into a working outlet and see if it stays on.
If it doesn't stay on then take the battery out and only hook up the ac adapter to it and see if it stays on.
At that point if it doesn't stay on, try to use another AC Adapter to see if it stays on, if it doesn't then you know for sure the main board is bad and you would need to get a new ds lite.
Jan 01, 2010 | Nintendo DS Lite Console
Overcharged the battery
Try to get a new battery off the internet somwhere (like ebay) they would be quite cheap
Dec 29, 2009 | Nintendo DS Lite
Nintendo DS Will Not Charge
Try if the battery is charged right, when batter is fully charged disconnect from AC adapter. Hold the power button for 5 seconds. If it does not work that means that you need a replacement battery for the Nintendo DS. When you receive the replacement batter, follow the steps again.
Sep 11, 2008 | Nintendo DS Lite Console
US Nintendo DS-Lite with converter problems in South Africa
It should work straight out with a step down transformer. That is of course if the mains supply in South Africa is 240 240 and the unit being American is 110.
This is of course not unless it was initially tried without a transformer or stepdown converter which would mean that the charger/adapter has been fried and therefore damaged.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Nintendo DS Console
To use Nintendo DS lite in India
The easiest solution is to buy a UK one and buy a UK-to-India plug adapter.
They use the same voltage as the UK (240 Volts, alternating at 50 cycles per second [50 Hertz]).
Using a US adapter in India could blow the adapter or DS.
Aug 22, 2008 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Nintendo ds lite the adapter is stuck in the port
never do things like that.did your ds lite come with a ac adapter?did you check in the box?if not call the nintendo experts 1-800-255-3700.they will either take it out and send it back to you or give you a new one (and u must pay if they cannot take it out)
Dec 25, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
160 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
