The freezer is leaking water into the fridge - shifted food in freezer, cleaned up mess. Air flow is good now. Will the increase air flow and the normal defrost cycle clear up problem?
Re: The freezer is leaking water into the fridge -...
You have to clean out the drain under the aluminum fins in the freezer. its called the condensate drain, blow out with compressed air or clear with thin metal wire.
*** The following is for information only.***
* The symptom of melted ice and water dripping from tray is usually caused by several things;
* Most common is ice build up in freezer coils. This happens every time the door is opened. Ice builds up on coils but is normally removed during a daily defrost cycle.
* The cycle may be unable to defrost all ice due to bad air circulation. Usually caused by rubbish blocking fan intake (bottom of freezer tray or wall.) Overloading food may cover the intake.
* Remove all food from freezer. Check for fan blockage. There should be a steady flow of cold air. If not then your freezer needs to be defrosted.
* Defrost by moving all frozen food to fridge side or cooler. Unplug fridge and open freezer door (drawer). Allow room air to circulate into the freezer. Use a house fan to blow air into freezer. (DO NOT use Hair dryer! It will damage panels.)
* Check and remove melted ice water. Check inner panels of freezer. Once defrosted the panels will be room temperature to the touch. There should not be any condensation or coldness to the panel. If it's still cold then keep defrosting.
* Once the water stops dripping. then close freezer doors.
* plug in freezer and wait 5 mins. Check freezer if inside is cold and the air is blowing cold. Reload freezer with food, take care not to overload or cover fan intake. Monitor for 2 days.
How To Check the Temperature
In most refrigerator freezers, the refrigerator
gets its cold from the freezer. The evaporator fan circulates air
over the coils in the freezer and cold air circulates into the refrigerator
through vents. If the vents are blocked or closed, then the fridge
will not get cold enough but the freezer will. If neither is cold
enough, then the number of possibilities increases.
Lowering the freezer temperature will increase
the cooling cycle activity. Setting the refrigerator temperature
may have little affect on the cooling cycles because it simply changes
the vent opening size. Decreasing the fridge temperature opens the
vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls
found inside the refrigerator or freezer. The ideal freezer temperature
is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water
with a cooking thermometer into the refrigerator for about 2 hours
or more. To
test the freezer, substitute alcohol or cooking oil.
Goodluck, Please don't forget to rate the solution.
Is there frost in the freezer section at or around the bottom? If so a defrost problem might be the issue. Here is a test for the air flow issue. At the air inlet of the fridge section, put your hand up there, is there air flow with the freezer door closed? With the freezer door open is the air flow better or increased? If air flow is increased, chances are the you have an air flow restriction between both chambers and you will need to locate the obstruction. So with this information this should lead you to a conclusion that is ice is on the evaporator you have a defrost issue, if you have no ice, than look for air flow issue.
HI, sounds like you have 2 problems. First of all, your drain pan in the freezer is clogged and will need to be cleaned out, second: this ice has caused an air flow restriction to the refer section. When you clear out all the ice, look for obstruction that you prevent clean air flow to the refer section. This should solve the problem.
You may have to remove all the food from the freezer, remove shelves and rear wall to clear all the ice. Failure to remove all the ice can prevent air from circulating from section to section. I would not suggest in using a hair dryer, too much heat in the wrong place can cause damage to the liner in the form of warping.
Turn off the unit while doing this de-icing, this will help greatly.
Good Luck
Your looking for a water leak and what you have is a air leak. One of the doors are not sealing right. Check the door gaskets for a good seal, clean the edge of any dust. Also pull the fridge out from the wall good remove the rear cover and vacuum out the coil on the bottom. Having a good clean coil helps to evaporate the watter in the pan. If not enough air flow over the coil the pan may stay full longer. Humid air gets pulled into the fridge thru the door seals and during defrost drips into the pan, where the heat from the bottom coil helps to evaporate that water. Other causes are too many door openings, keep that freezer door closed as much as possable in the heat of the day.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
