Question about Kenmore 17459 Free-standing Dishwasher
Leaking on the bottom
My dishwasher is leaking water onto the motor...
  • Kenmore Master
  • 12,061 Answers
Www.applianceaid.com/dish.html
www.apwagner.ca/index.php?main_page=page&id.
http://www.servicematters.com/maytag_library/docs/16010622.pdf
Service manual, above that are DOY help links. http://www.repairclinic.com/Dishwasher-Repair-Help
Posted on May 04, 2010
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Buzzing sound coming from bottom of dishwasher when it is running
Hello- Motor bearing is failing because a little seal on the shaft is leaking water onto it. Motor is about 100$ - Labor about same, unless you do it yourself. Hope this info helps- have more if needed. -Thanks. -ED
Mar 06, 2010 | Kenmore Dishwashers
Dishwasher is leaking in front onto floor. Water level during washing seems too high. Float is not obstructed by any object. What can I do next?
if it seems to be coming from the front it may be the rubber door seal they are not to expensive and not very hard to change if it is leaking under machine it may be the seal that sits on top of motor if water is leaking around motor the seal in the bottom of the washer is damaged
Dec 17, 2009 | Washing Machines
Whirlpool Dishwasher GU1500XTL Leaking from wash motor
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
q3taga
Aug 31, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
Water leaking out bottom of dishwasher door onto kitchen floor.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Mar 02, 2009 | Kenmore 15762 Dishwasher
Maytag MDBH950AWB Leaking
Leaking Dishwasher
heatman101
zgwerty
Feb 23, 2009 | Maytag 24 in. MDBH950AW Built-in...
Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Oct 23, 2006 | Maytag 24 in. MDB4000 Built-in Dishwasher
Kenmore 17459 Free-standing Dishwasher Logo
681 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
