Question about AOC 193FW LCD Monitor
Has a blue dialog box that says out of range
I have a blue dialog box that says out of range H.Frequency 75 khz and V.Frequency 60 hz none of the bottons on the monitor are working
    Novelist:
  • 138 Answers
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
Posted on May 04, 2010
How can I adjust the height of the HP LP2465 24" LCD Monitor?
MOST OF THE TIME THEY WILL NOT ADJUST UP AND DOWN. LOOK FOR A SMALL LEVEL AT THE BOTTOM OF THE BASE OR JUST BEFORE THE BASE. I JUST GOOGLE IT AND FOUND PICTURE OF IT.
May 21, 2014 | HP LP2465 24" LCD Monitor
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Display
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Regards,
nicam49
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
In the middle of my screen a blue box is showing and in it this reads OUT OF RANGE H. FREQUENCY 68.7 KHz V. FREQUENCY 85.0Hz What does this mean and how can I fix it this was a gift...
That message appears when the Windoze display settings exceed the monitor capabilities. If you will boot into windoze safe mode (F8 at boot) and correct the display settings, the message should clear at the next boot. Afterwards you can right click on the desktop and access the display settings to make final adjustments.
In your case, the refresh rate (V Frequency) should not exceed 70 Hz
Nov 23, 2009 | Envision H22W 22" Monitor
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
A_turkovsky@yahoo.com
ya u enable vga mode hit f8 at start up in xp select vga mode ok resets u then use 60 hertz man and its native res ok only update drivers ect mark me ask fit ya ok thx nick
Feb 08, 2008 | ViewSonic VX1935wm LCD Monitor
AOC 193FW LCD Monitor Logo
261 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
