Question about Kenmore Washing Machines
Error code F50 on Kenmore Elite Oasis HE.
I have a Kenmore Elite Oasis HE. The wash cycle stops and flashes F50 shortly after starting. What does this code mean? And where can I find a list of trouble codes for this washer?
jsrock516
  • 5911 Answers
SOURCE: looking for a manuel for a kenmore elite oasis he,stopped washing
If you are looking for a REPAIR manual, each one of these washers come with a technical data sheet located inside the front panel of the appliance. The tech sheet includes all diagnostics procedures, error code definitions, troubleshooting flow charts and wiring diagrams. To access it, you can pop the top panel open by locating the two retaining clips in the seam along the front of the washer where the washer top and front panel meet. About 2 inches in from each side slide a putty knife into the seam and push in to release each clip. Hold the lid shut as you lift the top. The tech sheet is located on the inside of the front of the washer between the wash tub and casing. Or....you can have someone lift the washer and tilt it back and you can try reaching up from the bottom between the wash tub and front casing.
If you need an OWNER'S manual, you can go to managemylife.com and type in the your model number under the "Manuals" link. They have an extensive list of manuals in .pdf (Adobe) format that you can download or print for FREE.
I hope this helps you.
Posted on Feb 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: Oasis HE 27082 Stainless Steel Top Load Washer: I have KENMORE ELITE Oasis He and it kept repeated...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Ellite Oasis - model #27042603
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: My kenmore elite oasis washer model # 110.2703 shows code F-50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 28, 2010
jharvey572
  • 447 Answers
SOURCE: my kenmore elite oasis he
from what i can find out it apears to be the rotor position sensor which seem to be a common fault it apears you need a new board to fix the problem
Posted on Aug 14, 2011
My Kenmore Elite Oasis HE is flashing a code "F50", can you tell me what the error code means?
Oct 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
May 25, 2010 | Kenmore Oasis 27042 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer won't start spin cycle, error f50
The F50 error on the Whirlpool Cabrio / Kenmore Oasis points to the basket and possibly some obstruction keeping it from turning freely.
Please see the following PDF Service Manual for the Whirlpool.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F50 alarm on my kenmore oasis washer
Sep 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Jun 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27062600 Fault code 50
Any solution? I have the same F50 error code.
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
495 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
