Question about Mitsubishi VS-50705 50" Rear Projection Television
How do I remove the screens on a 55" widescreen Mitsubishi rear-projection tv?
  • 178 Answers
I hope it could help.
Posted on May 04, 2010
Testimonial: "Just what I needed - screw locations and what direction to move screen assembly to remove it. And a quick response! Thanks a lot."
  • Shukai Fung
    Shukai Fung Jun 07, 2010
    Thank you so much for you came back to said thanks.
  • Shukai Fung
    It is very nice of you, have someone came back and say thank you is more difficult than solving 100 problem of TVs.
We can set the convergences great but after about 10 to 15 minutes ithe reds lines start moving a little again will not stay in position. It's a widescreen Mitsubishi rear projection tv ws-55857.
The problem - you're setting the convergence settings, but you're not saving them, you're
simply exiting the menu screen. Be sure to save your convergence setting for each
of the three colors. It sounds like you're setting RED last, and not saving its convergence setting,
whereas the GREEN & BLUE are holding their convergence settings, since you're saving them
correctly before proceeding on to RED....
Mar 15, 2011 | Mitsubishi WS-55857 55" Rear Projection...
Cracked front glass
U out of luck,not worth to replaced the screen,the screen it same as the new tv.The tv compannies sell out tv screen as a new tv.The tv 95% worth is in the screen.
Dec 23, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS4542
when you mean "stuck" in widescreen mode, is it due to a boarder or is it something else. Using the remote control you can make the necessary changes such as DPI, Borders, etc...
let me know if I can help any further...
Good Luck....MetalDad
email: PentiumDreams@aol.com
May 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi TV rear projection (Model ?)
No worries = generic note applies to more than one model....
Note:Use no cleaner on screen / lens caps = dry soft cloth....T.
Nov 08, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Format stuck on Mitsubishi WS-55511 Rear Projection TB
Normallly, if the format button on the remote does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Mar 04, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
