Question about Craftsman Garden
Replace or seal gas tank
The gas tank on my Craftsman LTX1000 has split along the seam, how do I replace ro seal it?
  • 2,100 Answers
Is it a metal tank? They can be repaired easily, but probably just as cheap to buy one. By the time you go through the trouble to fix it, you could have bought a new one and had the lawn mowed. A product called POR, is a gas tank sealer and it works great.(metal only) Just follow the inst on the can and you will be all set. Hope this helps.
Posted on May 04, 2010
HOW DO I PREVENT AND GET RID OF CONDENSATION IN HADLIGHT ASSY
Condensation in a headlight assembly usually means a crack or split in the assembly somewhere.Remove the assembly and use a hair dryer to dry it out. Go along to an auto supply store and get some "seam seal" (not silicone) and a silicone based lubricant.Spread the seam seal around the join in the headlight assembly and let it dry up.This is usually overnight.Take the silicone lubricant and apply it to the rubber gasket around each light bulb.DO NOT get the lubricant on the bulbs. Replace the bulbs in the assembly.This should solve your problem. Good luck
May 05, 2014 | 2006 Chevrolet Equinox LT
I need a new gas tank for craftsman mower ltx1000 but I have no model number
It was probably made by poulan. A poulan dealer will have a cross reference and they can get you one.
Jan 14, 2013 | Craftsman Garden
Yard Man Gas Tank Leaking
replace the tank if you patch it and it fails when the engine is hot a fire is not worth what your trying to save try sears parts online to price it out
Mar 27, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Emissions code is showing code po442. Cannot find any leaks. Already replaced gas cap. What is the other most obvious problem that can be fixed easily?
Common Problems That Trigger the P0442 Code
  • Defective or damaged fuel cap
  • Distorted or damaged Fuel Tank Filler Neck
  • Small tear or puncture in the Evaporative system hose(s) and/or Carbon Canister
  • Defective Fuel Tank Sending Unit gasket or seal
  • Small split in a seam of the Carbon Canister
  • Defective Evaporative Vent Valve and/or Evaporative Purge Valve
  • Defective or damaged Fuel Tank
  • Defective Fuel Tank Pressure Sensor
  • Defective Leak Detection Pump
  • Slightly loose and/or worn clamps or hardened O-rings anywhere in the EVAP system
Common Misdiagnoses
  • Fuel cap
  • Evaporative Purge Valve
  • Evaporative Vent Valve
Jun 05, 2011 | 2002 Ford Explorer
Can this code p0442 be the gas cap?
Dec 30, 2010 | Toyota Avalon Cars & Trucks
Y28 gas tank leaks along the seam. Probably need new tank. Can the tank be replaced? Where do I get one?
Yes the tank can be replaced. You need to go to your lawn mower shop with your model and serial number, and the can order you one.
Nov 09, 2010 | Yard Machines 11A08MB006 22Inch 139cc MTD...
My tb425cs leaks gas when it is running. It drips from the bottom of the gas tank.
Be sure to not overfill the tank. Just load it with gas up to the bottom of the neck and be positive you're not cross-threading the cap when twisting it on. If it only leaks when operating, see if there is fuel bubbling out through the vent(s) in the top of the cap or out from under it. Also wipe the tank clean and dry to be positive it is not leaking from a seam or crack in tank or around fuel lines. If leaking from cap, might have to replace as they do have an internal rubber seal that could have gotten dry or cracked. If it's from the tank seams or fuel lines replacement may be neccessary of either one or both.
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My gas tank leaks if it gets over half a tank
sounds like a seam on the tank has either split or rusted away, better get to a garage...or keep it under 1/2 tank.
Mar 22, 2010 | 1990 Mitsubishi Galant
Gas tanks rupture on craftsman lawn tractors
2 of them, one is take it to craftsmen and see if they will fix it as a manufacturing defect, or you can replace the tank yourself. There is a putty that you can use, just go to the auto parts store and tell them what you need. Some of them can't be used on gas components so be careful or you will be right back in this mess, only with a bigger mess on your hands.
Calvin.
Apr 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
233 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
