Question about LG Art Cool LA181CNW Split System Air Conditioner
LG Art Cool Error Code CA
I have an LG Art Cool it is displaying "CA" error code. I have shut the unit down for over a day and the code is still displayed. I have read where this is caused by the compressor overheating. Is this correct and is the a reset I need to perform?
  • 2 more comments
  • oldtrucksrul May 06, 2010
    Redniten, I flipped the circuit breaker off for a day and then back on. I'll try to determine the leds for you soon. Thanks for the help
    Redniten, I flipped the circuit breaker off for a day and retried later to no avail. I'll have to check for the leds soon. Thanks
  • Brian Niten May 11, 2010
    When you shut it down did you disconnect the power or just turn it off?
    I was looking at a book for the LG mini splits and I didn't see an error code CA. I'm not saying I don't believe what you are saying I'm just saying I don't see any reference to it. Are there any lights blinking on the inside unit. The ones the book mention look like a circle with a line inside it and another that looks like a star or snowflake. If these are flashing count the number of flashes. It also mentions some LED's on the ciruit board in the outside unit. Check those to see if they are blinking and count the # of blinks. It will be a repetitive pattern. As far as the thermal overload on the compressor I think it is self resetting but you can check it. It will be on top of each compressor (your unit has 2) under a black plastic cover where the wires connect to the compressor. Let me know if you find any blinking LED's on the outside unit or blinking lights on the inside unit.
  • 2,133 Answers
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
Posted on Jan 03, 2011
  • paul_crafer
    paul_crafer Feb 22, 2012
    R Subramaniyam Iyer, is your comment above a solution anyone can use or do I have to give this to the AC guy and he'll know what to do?
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
Have an lg dfs unit not working cooling lamp flashes 7 times heat lamp 6 times what is the problem?
DEFINING COMMON ERROR CODES www.lg-dfs.com/.../dfs-tp-ag-002-us_012h29_lgtechpaper_errorcodes-la... Aug 29, 2012 - Refer to Service Manuals posted on www.lg-dfs.com to troubleshoot individual error codes. Error. Code. Description. No. of Times Indoor Unit ...
Mar 02, 2015 | LG LSN121HSV LSU121HSV 1 Art Cool Ductless...
C9 error code lg cool art
let the technicians do it for you,one of their sensor got faulty
Apr 21, 2014 | Heating & Cooling
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
Heatpump LG Art Cool mirror shows error code ''CA'' in display. HELP!!!!!
I'm getting the same code but no luck of it fixing its self. Is there another fix or reset?
Jan 08, 2010 | LG Heating & Cooling
Error Code on LG Art Cool
error code CH22 is either compressor or inverter fault.
Jun 01, 2009 | LG Art Cool LA091HNP Split System Air...
LG error CH 64
What is the model of the unit?
Apr 07, 2009 | LG Art Cool LA121CNP wall/window Air...
Displaying "Co" code, and running when turned off with the remote
It sounds like you have lost communication between the indoor and outdoor units. This can be one of two things. Either the connection indoor or outdoor is loose or bad, or a rat may have eaten the cable in cieling.
Feb 28, 2009 | LG Art Cool LA121HNP Split System Air...
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
LG Art Cool LA181CNW Split System Air Conditioner Logo
1,275 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
