Question about Buck Legendary: The Box for Xbox 360
My Xbox360 will not play Orginal XBox 360 Game Disc
My Xbox360 can play all CDs and DVD moves. But Orginal Xbox 360 disc will not play. Below message show on the scren
" This orginal Xbox game is not supported on your Xbox360 Console. An updates to support this game may be available.For more information go to www.xbox.com/games".
Version 1.0
Then I updated it but still show up above message.Any body can explane to what is wrong with my Xbox 360.
  • 27 Answers
That has to do with the actual video coding. try to clear the cache on your system then redo the update. this will only work 50% of the time after that you will have to send it off or get another. i had that exact problem and ended having to send mine off but they said to try it. it might work. (sorry for not thinking your problem through earlier.)
Posted on May 10, 2010
  • 15 Answers
Hack cheat repair and unlock xbox 360 yourself in less than 1 hour
http://3redlight.tk
Posted on May 04, 2010
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
I put Cd of Xbox360 game...It gives me a message"To Play this disc put it in Xbox 360 console". Please tell me what I do to play game having such meassege.. regards..!
1. all the disc are not region free , games from microsoft are region free, which means u can play in any kind xbox 360
xbox has different version like (ntsc, pal), some countries only accept ntsc some pal.
u can find it on right hand side of the dvd
if it is pal u can play omly pal dvds
u can also modify ur xbox360 this u cannot do by our own, once u modify u can put both version of dvds
hope u got the answer
Mar 14, 2010 | Microsoft Xbox 360 Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
Feb 18, 2010 | Microsoft Xbox 360 Console
Xbox360 will play cds but no games, says onscreen
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
Sometimes like you mention it will still play CD's though.
Feb 13, 2010 | Microsoft Xbox 360 Console
My xbox360 will not read disc, message reads
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using is causing the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
For disc-specific issues, check the disc for any visible signs of damage or dirt. Hold the disc by the edges without touching the top or bottom surfaces with your fingers. Clean the disc by using a soft cloth. Lightly wipe from the center outwards. Do not use solvents or chemicals to clean the disc.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1. If you have access to another Xbox 360 console, try to play the disc on the other console. Or, if the disc is a CD or a DVD, try to play the disc on another device, such as a CD player, a DVD player, or a computer that is equipped to play CDs or DVDs.
2. If you have an Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console, turn off the console, and remove the HDD and any attached MU. Then, turn on your console, and try the disc again. If this seems to resolve the problem, turn off your console, reattach the HDD and MU, and then delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight a storage device.Do not press the A button, Press the Y button to view the Device Options screen, Select Clear System Cache, and then select Yes to clear the cache.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked also if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Let me know of this helped and please do take time to rate my solution
Happy Gaming, Happy Holidays
Regards
KreativeGeek
Dec 29, 2009 | Microsoft Premium System for Xbox 360
Xbox360 game will not read
If your xbox is modded try a different brand of disc.
Obviously try and clean the disc itself.
Else your dvd drive is faulty and needs to be replaced
Mar 17, 2008 | Microsoft Xbox 360 Console
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Jan 14, 2008 | Microsoft Xbox 360 Console
Buck Legendary: The Box for Xbox 360 Logo
252 people viewed this question
Top Buck Video Game Consoles & Games Experts
James Wishart
Are you a Buck Video Game Console and Game Expert? Answer questions, earn points and help others
