Question about McCulloch MCCFH180B Electric Pressure Washer
Replacing a broken component on my McCulloch FH180B
While using my McCulloch FH180B to clean the deck this morning, the plastic component which connects the intake hose to the body of the pump broke in half. This is the component with male threading on one end and four machine screws attaching it to the pump on the other. I tried epoxying the part, but after turning the water on it just broke again. Is there a more permanent way of fixing this or somewhere to get a replacement, or do I need to buy a new washer? Thanks for your time.
    Brigadier General:
  • 4,090 Answers
Mc Culloch service centre Check the phone books pages in your country of origin ( or on the net). Your local hardware or distributor should be able to direct you to the service centre.
Cheap part ( $5) but they have a minimum labour cost of $100. So ask first if you can just buy the part and DIY
Please rate my help++++Thanks for using FIXYA
Posted on May 04, 2010
McCulloch ms354 on/off switch does not stop engine when switch to off position. Easy fix or does the module that connects switch to spark plug need replacing?
wire broken on the switch or switch is broken the switch is part of a very simple circuit that when switched on shorts to ground the wire from the coil
Oct 30, 2017 | McCulloch Garden
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Jul 22, 2015 | McCulloch FH180B - Pressure Washers -...
How do I remove the adjusting bar screw from McCulloch chainsaw
You'll need to contact your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
May 11, 2012 | McCulloch Garden
I have a Hacker Gondolier record player fitted with a Garrard 2025TC record deck. The record deck suddenly made a light whining noise then stopped rotating altogether. The belt is still intact. Will the...
First check to see you can turn the motor by hand. If it is stiff there's something wrong with the motor. If OK then have a look at the motor. If it works on 12 volts or under, you can attach a 9 volt battery PP9 type to it. If it's 6 volts, use a 6 volt battery! (You might have to remove any wires going to the motor to do the test). This should cause it to spin. If it doesn't it's dead. If it does check the voltage supply to the motor. Also check for broken plastic parts anywhere on the deck.
Dec 08, 2010 | Audio Players & Recorders
I am looking for a nozzle for a Mcculloch 1800 psi model FH 180B Can you help me? Thank you. Ken
http://ipl.ordertree.com/ipl/604/FH180B%20(DSC).pdf
There is the link to your breakdown, choose which part you need, then I would call them direct and have them send it out. Their Number is
1.800.521.8559
Let me know if this helps~!
Nov 23, 2010 | McCulloch Garden
I need to replace the nozzle on my FH180B. the
Common issue. Sounds like your nozzle is just clogged. You can try and run a wire through it to clean it or soak it overnight in white vinegar to loosen up the deposits.
May 01, 2010 | McCulloch MCCFH180B Electric Pressure...
Chain bar not getting oiled
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 and McCulloch it is most likely a defective hose or oil pump (see IPL).
You provide no model number, try for IPL here :
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | McCulloch Garden
Mcculloch chainsaw. Model 2116av. Primer bulb is
Hello Jeff;
Your saw is listed here:
McCulloch MTD
Chainsaws 32cc-35cc-38cc Anti-Vibe
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. The primer is displayed but not listed, and there is no part number. Before you get to deep please contact OrderTree.
http://www.ordertree.com/cms/parts-lookup-help/73.html
Use the IPL as a guide for disassembly/reassembly.
This is typical routing and a couple of hints.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
OMs for McCulloch are tough. harder than replacing the fuel line. Have your saw within easy reach they will want the serial number and a few other things.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
Good luck with your project. HTH
Lou
Feb 20, 2010 | McCulloch Garden
McCulloch MCCFH180B Electric Pressure Washer Logo
192 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
