Question about Kenmore 64802 Top Freezer Refrigerator
Black fluid leaking from 1 yr old Kenmore refrigerator from front left corner around wheel. No smell but very sticky.
    President:
  • 1,070 Answers
Perhaps your defrost drain is stopped up either in the freezer drain trough or further along is the drain system. Start by removing everything in the freezer and removing the panel that covers the evaperator coil to see if the drain trough under the coil is blocked with ice, if it is clear the ice and make sure the drain is clear to the pan under the box by running hot water with bleach thru the line. It could also be blocked in the area in the food compartment right under the freezer area, where the drain line drains into.
  • Find the defrost drain. The defrost drain should be a round hole or hose running along the floor of the freezer. Depending on your make and model of refrigerator the defrost drain could also be located at the bottom back of the freezer. You may have to remove the evaporator cover to gain access to it. If you still cannot locate the drain hole, consult the manual that came with your refrigerator.
  • Remove debris. Once you have found the defrost drain remove any debris such as ice or mold that has accumulated in the drain hole. A pipe cleaner or wire pushed inside the drain hole can help to remove debris.
  • Flush it out. The easiest way to flush out the drain is to use a turkey baster. Fill the turkey baster with hot water and blast it into the hose. This will force out anything that is clogging the hose.
Hope this make you better...Thanks for Contacting FixYa...
Posted on May 04, 2010
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
Leaking fluid around left front wheel of 2001 Audi A6
If it is near the tire it is brake fluid. The brake fluid reservoir is back by the firewall driver side of engine compartment. Your car uses DOT 4 brake fluid.
Feb 13, 2014 | Audi A6 Cars & Trucks
I have water leaking from the front left corner of my Kenmore elit refigerator. I have shut off the water feed and the icemaker switch
That is probably the 5/16" poly tubing running up into the door and to the water tank. You can get tubing and unions to fix that.
May 08, 2011 | Kenmore Side by Side Refrigerator
I have a 20 yr old Kenmore top load washer that has begun to leak from the left front area if you are facing the washer. How do I find the problem & repair it??
Usually leaks from here are the water pump or one of the hose front the pump are leaking. The washer will have to be turned on an angle side to get to these. very easy to replace.
Jan 09, 2010 | Washing Machines
I have an ONLY THREE yr old!! Kenmore side by side fridge w/ice maker. Refrigerator is cold, but freezer stopped freezing. I cleaned the condenser coils. didn't fix it. service tech came out, opened up...
not realy its the refrigerant gas thats leaked,, call the guy back and demarned he fixes it under the warranty,,,and dont take "no" for an answer,,, lurn to kick bu** to get whats yours
Nov 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Leak around left front wheel
I would check the defrost drain inside the freezer. this is real easy to do on this model refrig.
  • remove bottom basket (if it isnt frozen in place) and the shelf above it.
  • in th back just below the coil cover in the freezer section there is a ledge that will most likely be frozen over remove this ice using a hair dryer or hot water which ever is conveinant for you
  • you should uncover a drain hole flush this drain with hot water I use a turkey baster or large syringe to forcefully push water thru to clear anything in the drain
  • put it back together and you should be good to go
when ever the unit goes into defrost (which is about twice a day) the water runs over the ledge and then out of the door by the hinge puddling up next to the wheel. this unit has a hard fiberglass drain pan that is built in and unless it has been dropped i cant imagine the drain pan being damaged.
Let me know if you have any other questions Peyton
Mar 07, 2009 | Kenmore 74192 / 74194 Top Freezer...
Nasty smell in garage.....think its coming from refrigerator
It's either the drip tray which is removeable from the front, or, mice are playing in the drip tray under the compressor. Soak in up, rinse with some ammonia water & repeat a few times. Rinse well when done. Line up some sticky traps behind the fridge. The mice found a playground amd they will return.
Mar 07, 2009 | Frigidaire FRT15B3A Top Freezer...
Gassy smell in upright freezer
Is this a refrigerator in a household or an RV?
The reason I ask is that RV refrigerators use ammonia, which you can smell. If you read the article you probably read that Freon does not have an odor, in extreme cases you can smell burnt refrigeration oil when a system with a large leak has been left running, but by then the unit wouldn't be working.
If your refrigerator did in fact have a leak it wouldn’t be working, due to such a small amount of refrigerant present. ( typically about 5 ounces )
So, your gassy smell is likely from something else. I find this happens most often when potatoes or carrots are stored for long periods of time in the refrigerator, usually in the crispers. When starchy vegetables wilt ( get smaller with age ) they give off a gas. The smell eventually comes not from the starch, but from the bacteria that starts growing on it. All this happens on a microscopic level so you won't see anything. good luck
Dec 13, 2008 | Freezers
A leak from the fridge
Without knowing a bit more about the black fluid it is hard to guess where it could come from - in a fridge there should be no black fluid and the only oils are mixed in with the refrigerant so the fridge will not be working if any noticeable amount is leaking out, as the gas will leak out as well. As you mentioned, the most likely liquid is water from inside the fridge or condensation from inside or outside that has bacteria growing causing the blackness. this sort of water may usually only be in the water tray at the back but there are many possibilities of it leaking out somewhere else - only way to check is to get the fridge running, up on four chairs or a VERY strong glass table so you can see where it is comning from. Another possibility is that there is some insect, plant or rodent factor - the moist warm space under a fridge is quite popular and they can produce their own liquids and also especially rodents cause unpredictable holes and damage all over the place. also can only be checked by looking very closely at the source of the liquid. The last possible cause i can think of is some sort of corrosion - i have not heard of this type of corrosion with a fridge, but it is quite common on steel ships - salty humidity and chemicals (cleaners/cargo etc) reacting strangely with the paint or steel are normally blamed - just think if you get too many strong cleaning products near the bottom of the fridge and look for general condition of the paint/metal underneath you should be able to see it easily if the black fluid was in any significant quantity - there would usually be a sort of rusty look to the fluid, but not always depending on the combination of chemicals present. Where you describe the fluid coming from, sounds like it could be from the door insulation - maybe leaking through the bottom hinge holes - check that nothing is leaking into the door from inside, although condensation can easily happen in the door body itself if the insulation has separated slightly from the "skin" of the door inside. Last thing to try is to investigate the fluid itself a bit more closely - get some on a piece of kitchen paper towel or a coffee filter and then wet the paper with water also just next to the fluid- the parts of the liquid should separate out a little as the water soaks through the paper and you may just see something that looks familiar. If you get no luck post back and try to describe exactly what the fluid does smell like, without trying to imagine smells like "oil" which means nothing as they are all different and in particular fridge lubricants are relatively odourless. think of things you actually know the smell of and try and describe it in those terms - if you feel brave then it may be worth tasting the liquid - just taste a tiny tiny bit on a cotton bud/Q-tip dabbed on a few different areas of your tongue and then wash your mouth out with mouthwash straight after instead of spitting or swallowing - I know it sounds dangerous and disgusting but it is the way that many professionals identify unknown substances as taste has a much more specific "database" in the brain than smell has. just be sensible. Hope this helps - post back if not - photographs may help if you have a digital camera, especially of the coffee filter test if you get round to it :) Good luck
Jun 22, 2007 | Kenmore 64802 Top Freezer Refrigerator
Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Jan 15, 2007 | Frigidaire GLRS237ZA Side by Side...
Kenmore 64802 Top Freezer Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
