Question about Mantis 2-Cycle Tiller
Tiller won't stay cranked
Tiller will start, but doesnt continue to run. did have old fuel, but dumped that and put in fresh. problem continues
  • 198 Answers
The carb needs a thorough cleaning
Posted on May 04, 2010
Hard to start, won't stay running.
I would suggest that if the fuel mix is over 2 months old dump it out and put in fresh fuel.
Mar 23, 2015 | Garden
Brand new mantis motor/started when i got it let set for a couple months wont run it will start on choke
The first thing I would do would be to dump out all of the old gasoline mix from the tank and replace it with fresh gasoline mixed with the proper amount of 2-cycle oil.
Jul 21, 2014 | Mantis 2-Cycle Tiller
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
Dec 14, 2013 | John Deere 826 1032 Snowblower Operators...
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Tiller will not continue to run. It has good spark. It will start if primed through the carburator but once the prime burns off it dies.
If fuel sits in the gas tank 3 months, the fuel deteriorates and it gums up the filter in the tank. You need to put stabil in the tank. This has happened to me over and over. It is best to dump out the gasoline if you don't use the tiller within one month. Some people who use chain saws commercially dump all the gas out every day and start over the next day. The symptoms are the tiller won't run at high speed at first, then as it gums up more
it won't run even at low speed, then becomes hard to start.
The gum is hard to see. Pull out the gas line to get to the filter and change the filter. Filters are only 3 or 4 dollars at hardware stores.
Jun 01, 2012 | Honda 25cc 4-cycle Mini Tiller
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
Had some gas in a can, so i poured maybe a gallon of it in my tank to make it to station. then found out it was diesel fuel. i only drove it a block and noticed it tryin 2 boggle out on me so i parked it....
Diesel should not hurt your car as long as you did not put to much in your tank. I would recommend that you buy a good bottle of octane booster dump it in your tank then fill it up with a high octane full like 91 octane. That should make up for the difference. Your car may smoke a little bit until all of the diesel is out of your system but it should be fine after that. I hope this helps and if you have any other questions please feel free to ask.
Sep 19, 2011 | 2002 Dodge Intrepid
Will turn over and run for 1/2 second. Will not continue to run.
Check fuel filter, and next step fuel pump. Make sure is fresh gas. Try spraying starter fluid, if it still shuts off it is probably fuel filter or the fuel pump.
May 08, 2011 | Troy bilt Super Bronco Tiller 208cc
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
I can't get it to start, it just sputters for about 10 seconds and cuts out.
If your tiller sat all winter it will need a little work. Drain all of the old fuel out of the tank, install a new spark plug and install a new air filter. Put new fuel in the tank [if you still have old fuel in your portable gas tank dump it into your car or truck so you start fresh for all of your small gas engines.
Now crank it over and it may start. If it doesn't start you need carbeurator cleaner. But an aerosol can of carb cleaner and put two squirts in the air intake [remove the new air filter and leave it off while you get the engine running]. Pull your cord, turninng the engine over and possibly starting it. If it starts, great. If not, let it sit for half hour while that carb. cleaner dissolves some of the gum built up in your carberator over the winter. Two more squirts of carb cleaner and try to start it again.
Generally it will start by now. If it doesn't start your carbeurator must be really dirty. You will have to remove it, and soak it in carb. cleaner for about three hours to clean it out.
May 27, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
229 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
