Question about Speed Queen AGS28AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
Gas dryer. Drum belt recently replaced. All motor contacts are in place. Speed Queen model -R155DF.
  • Speed Queen Master
  • 43,501 Answers
If you have a gas dryerDryer does not heat.  Electric ignition does not .
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
What's your problem?Squealing Speed Queen dryer
The drum of the dryer has a belt that turns the drum while in operation. These belts are not hard to replace and if your old belt is still attached you can visually see how it is positioned on the drum. However, there are also at least three rollers that carry the drum allowing it to rotate as it is being turned by the belt. These rollers are also not that expensive and are relatively easy to replace. Since the machine is 20 years old you may experience some problems finding the parts (maybe not)> You can check with the company via the internet and find out. Just give them the model number and a description of the part. The pulley that is attached to the shaft of the motor that drives the belt that turns the drum could also be worn out. Replacing the pulley on a machine that old can be trying but not impossible. If you have a technician check out and make repairs on these potential problems it probably cost well over $180 but if you have any mechanical ability you can probably do the job yourself if you can locate the parts. Just make sure the machine is unplugged from an electrical source before removing the back and the rest is just work.
Dec 12, 2011 | Speed Queen Dryers
Problem is blowing cold air not heating up,its a speed queen dryer on bottle gas ?.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 14, 2011 | Speed Queen Dryers
My speed queen model# AES68AWF doesnt heat what could it be?
heatman101
Jul 16, 2011 | Speed Queen AES68AWF Dryer
My speed queen dryer model #AES68AWF doesnt heat what could it be?
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
I have a speedqueen gas dryer model AGM499w iGNITER LIGHTS BUT NO FLAME
heatman101';
May 24, 2011 | Speed Queen AGS28AWF Gas Dryer
My dryer does not tumble the belt is not broken there is a clicking and rumbling sound coming friom around the motor speed queen model AES17AWF
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Apr 20, 2011 | Speed Queen AES17AWF Electric Dryer
My speed queen gas dryer comes on but will no longer heat. The igniter is fine.....passes the Ohm test. What might be the solution? And what are the est. part costs....this is an old speed...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It works on amps... not ohms...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Dryers
Speed Queen Commercial Dryer model EE111OL (electric) got wet in recent flood, still spins but not getting heat. Is it the thermostat, sensor or igniter that is bad and needs replacement?
If this dryer was submerged any component that was in water needs to be replaced. NOT cleaned and reused. there could be water in he burner and any electrical or mechanical component that was in water will soon fail if it hasn't already. This is a safety issue. Please have this repaired as if your life depends on it as it may.
Eric
Jul 30, 2010 | Speed Queen AES28AWF Electric Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dyrer won't heat...
I can not find a diagram using your model number.
However, most Speed Quenn dryers have 2 screws on the bottom right and left sides of the front panel.
Unplug the dryer.
Remove the 2 screws.
Lift the panel forward and disconnect the door switch wires.
Reemove the belt and drum to access the heater circuit.
Jan 20, 2009 | Speed Queen AES28AWF Electric Dryer
Speed Queen AGS28AWF Gas Dryer Logo
291 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
