Question about Sylvania LC320SS8 32 in. LCD Television
Need codes for a sylvania tv to get to the auxiliary so I can hook up the ps2
  • gadiffl Jul 28, 2008
    have same problem with same tv called cable co and sylvania no anwsers
    Problem Solver:
  • 11 Answers
Buy an HDMI cable to use instead..No code needed
Posted on Jul 31, 2008
How do I view my PS2 video on my Sylvania W4913TA 13" TV?
Hi Casey.
To view your PS2 through the Tv you will need the AV lead from ps2 with the Yellow cord plugged into the Yellow RCA input on the front of the TV. This is called a "Composite" video signal and the AV lead can be bought easily from places like eBay and Amazon if you have not already got one. Normally on the TV Casey if you choose "Aux" it should display the channel that you inserted the lead to. Aux being short for "Auxiliary".
I presume you are in the USA Casey.
If so the best way to view PS2 on a Tube CRT would be either Scart (RGB) or Component video. RGB TVs are not normally sold in the US but some tvs have them. Component video input should be readily available in USA tvs and this will give you a much better picture and is the highest video quality the PS2 can do. A few years back Samsung made a great CRT tv with component video and also scart and it could also do HD gaming.
If you cannot get any of these TVs and have to use the new Sylvania its cool. The yellow video plug inserted into the front of the tv and I have checked on line for the instruction manual and you will have to press " Game" on the remote control which is the same as pressing "AUX" input.
I think this button has to pressed and at the same time it sets the mode at which you will be viewing the PS2.
In game mode the contrast and brightness are normally tweaked to give the best results.
I hope my answer helped you out Casey and good luck with your new TV :)
Oct 28, 2014 | Televison & Video
Sylvania dvc865f
You hook your composite or component video and audio from the PS2 into the DVR inputs. The outputs from the DVR then need to go to the TV. Make sure that when you want to record, the DVR is set to whatever input the PS2 is plugged into
Nov 08, 2013 | Video Game Consoles & Games
Need codes for sylvania tv modle 6319CB using a
hi! i have here a code for your sylvania TV/VCR just try them 1145, 3095, hope this helps!!!! goodluck!!!
Apr 07, 2010 | Sylvania 6319CE 19 in. TV/VCR Combo
Need Sylvania program codes for (CRK59B)RCA
I have the manual for the RCA TV that the CRK59B came with. The Sylvania VCR program codes are 08, 29. If you're trying to control a Sylvania Cable -TV Box, the code is 11.
Aug 28, 2009 | Televison & Video
Need remote code for LC420SS8
SEARCHING FOR YOUR CODE
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
Turn on your TV.
On the remote control, press TV once. Then press and hold Setup until the key blinks twice, then release Setup.
Enter 9 - 9 - 1- 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device.
Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
Press Setup once to lock in the code. The TV key will blink twice.
To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the auxiliary device you are searching for.
Apr 05, 2009 | Sylvania LC420SS8 LCD TV
Remote codes
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Was this solution helpful? Show your Appreciation by rating it:
Nov 08, 2008 | RCA RCU600M Remote Control
Programming it to a Sylvanvia TV model 6420FF
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Trying to get ps2 to play on new tv..
USE a VCR between the PS2 and the Sylvania TV.  Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4.  Set the VCR channel to Line 1 or Line 2.  This should work. I hope it helps you.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
Sylvania LC320SS8 32 in. LCD Television Logo
48 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
