Question about Nikon COOLPIX L5 Digital Camera
Shutter did not close - Nikon COOLPIX L5 Digital Camera
  • 4 Answers
Sounds like it was dropped. Check with Nikon.
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Posted on May 04, 2010
I have a hasselblad 503cx. when i hit the shutter button, the back part of the lens opens (where the film is) but the lens shutter is closed. when i let go, the lens opens and the back closes.
The proper order of exposure should be:
Curtain opens/Lense stops down (unless wide open)
Lense shutter closes
When releasing button, curtain closes
When winding, lense shutter opens
If this isn't what's happening, something is wrong. There is only a simple mechanical screw connection between body and lense, so it'd have to be an issue with the gears in the body.
May 21, 2011 | Hasselblad 503CX Medium Format Camera
The shutter is stuck closed - i also would like to set camera to original standard settings
A stuck shutter is another common failure mode for digital cameras, especially for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 05, 2010 | Canon PowerShot S2 IS Digital Camera
When i take it to develop film cames back the shutter not closing or opening ? on pic onit at all
I would check the shutter by:
1) open the film door
2) While looking into the camera, press the shutter button.
The shutter should open and then close. If the shutter doesn't open and then close, it could be stuck and my require professional help.
Jul 01, 2010 | Nikon N75 with 28-80 lens 35mm Film Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
Shutter wont close
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
May 16, 2010 | Pentax Program Plus 35mm SLR Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
Jan 15, 2009 | Bronica ETR-Si Medium Format Camera
Shutter opened but won't close
Switching off the camera from the main ON/OFF swit5ch should close the shutter. If it doesn;t, try removing the battery or the CF card. It is possible to manually increase the shutter speed even in bright sunny conditions.
Jan 09, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Shutter won't close on Nikon D70s
Format the card. I have same problem with mine ---requires a new shutter assembly.$40.00 item and they want $300.00 to fix it at Henry`s cameras. Ouch .Better to buy a new camera.
Nov 19, 2006 | Nikon D70s Digital Camera
Nikon COOLPIX L5 Digital Camera Logo
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
