Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Lenovo s1o number lock stuck. i am unable to use keyboard. FN key non responsive. any suggestions are appreciated!
    Novelist:
  • 138 Answers
Hello
If the key is physically stuck in the "down" or pressed postion, the key may have become disconnected from the mechanism underneath that returns it to the "up" position.
All keys on all keyboards can be removed. This includes laptops. On laptops, the keys typically have less travel (up and down) than a desktop keyboard and the key attaches to the keyboard differently.
In either case, use a small screwdriver or your fingernail and gently lift up on the key - to return it to the "up" position. When in that position, see if the rest of the keyboard works.
If it does, you can simply lift up on the key and remove it from the keyboard. The support that is underneath will either be removed with the key or will remain on the keyboard.
Re-attaching the key involves aligning the key with the ends of the support bracket and snapping it back into place. (Most keyboards have a white plastic structure that forms a X on 2 sides - allowing the key to move up and down.)
With the key removed, look at the edges of the surrounding keys to get an idea of how it attaches, align the parts and press it back into place.
Posted on May 04, 2010
Lenovo p580 numlock off
What options have you tried ??
Number Lock on IBM Laptop Computers b> Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
also Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Jan 30, 2013 | Computers & Internet
Tip
FIXED keyboard stuck in fn mode ...
keyboard stuck in fn mode ASUS eeePc .. what you have to do is press and hold the Fn key, then while holding the Fn key, press Num LK or Number Lock key, That should fix it. Good luck!
on Feb 10, 2010 | Computers & Internet
Numbers are locked
Use FN key and Num Lock to dissable
Nov 13, 2012 | Lenovo Ibm 55y9003 Thinkpad Us Keyboard...
Hello, the 'Fn' key make me type numbers and
press Fn + nmLk, it will resolve the issue.
Oct 14, 2010 | Lenovo 3000 Y410 Laptop
I have purchased Lenovo G550, i am unable to use web camera.pls suggest which antivirus is best per lenovo G550 for internet usage .pls suggest
Please click on this link to download the driver for the camera...
For the Anti Virus, to tell you honestly,it really doesnt matter which Anti Virus you are going to install as long as its always updated...
Note: Press Fn Esc, that's how you disabled/enabled camera
Hope this will help... Your response is very much appreciated...
Sep 07, 2010 | Lenovo Computers & Internet
Vostro 1000 Fn locked
This is ****. Respondent doesn't know the model in question and his suggestion is of no help--there is no "blue lock" graphic imprinted anywhere on the Vostro 1000 keyboard. A user with this sort of question is already frustrated and does not need his desperation exacerbated by a nonsensical response from someone calling himself "RescueTech".
The user, on the other hand, may be excused for believing the problem is a locked Fn key--Dell does you no favours by printing the alternate number labelling in blue, AND the problem is reversed as long as the Fn key is held down--but the actual culprit is Num Lk. You'll find it on the top-most row, five keys from the upper-right-hand corner. Press it once and your problem will vanish.
Apr 03, 2010 | Dell Vostro 1000 Notebook
When i press a key with a letter and a number the n4mber appear. i have to press fn for the letterns to work
press Fn+ numlock key for some laptop its F8. that will disable the number lock. thanks
Mar 28, 2010 | Lenovo ThinkPad T61 Notebook
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Sep 20, 2009 | Compaq Keyboard
Keyboard Issues/Errors
I would gather that your keyboard has been changed somehow to another country keyboard. Please check in your control panel, keyboard and see if eng usa is selected.
The other suggestion is pressing and holding fn key, num lock key at the same time. You should see a light going off and on when you do this on your system.
If keyboard selected is english, and num lock is off, I would turn your keyboard upside down and give it a good shake. Sometimes a paperclip, or staple gets underneath the keys.
Jan 22, 2009 | Averatec Computers & Internet
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
266 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
