Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
My nieghber gave me a 14 inch poulan saw .but wont start.told me he started to have trouble with it and doest has the time to repaire it uses his other.i put a new sparkplug and still nothing.clean everthing up ,carb ,air filter,fuel lines.should isee gas go throug line up to the carb when priming gas . ?cause i dont ,if i pull off the line gas comes out with little pressure. i need help
    Brigadier General:
  • 4,090 Answers
Firstly, the answer re fuel going up the line is YES!
It sounds like a lack of compression. Take out sparkplug and place finger over cavity whilst pulling starter cord. The pressure should be strong enough to push your finger off the hole. If not, then the rings are shot or there is a hole in the top of the piston.
This will cause poor run in the fuel line to the carburetor. so the carbi is possibly empty or not full enough. Check the float level or that the float, actually floats. It sounds that that float is OK as its not flooding, but take a look anyway it may be jammed shut.
Lastly.. check the spark lead where it goes inside the body as this screws onto a screw to make contact with the inside of the leed. Get a new leed as these carbon based leeds fail after a short time anyway.
Presumne you checked it was actually sparking well?
These are the things that commonly affect chain saws and brush cutters
Please rate my help++++Thanks for using FIXYA
Check the oil hole filler and see if the oil has fuel in it. This is a good indication of poor rings and holes in psiton
Posted on May 04, 2010
Just purchased today 14 in. poulan starts but wont idle
Make sure you are using 40:1 ratio fuel mix.
With a chain saw owners manual usually recommends running engine for at least 60-120 seconds to warm it up before engine temperature is enough to where engine will idle.
Nov 03, 2016 | Poulan Garden
My chainsaw poulan p3314 will run fine for about five minutes, then cuts out and wont start until it cools down....???
Sounds like the engine is overheating and seizing. Most of the time this is a cooling or oil problem. Check the cooling fan for debris. Make sure you use the right oil mix.
Sep 16, 2013 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My chain saw will not start model #3314 14 inch I followed the directons on saw yet it will not start I also have the manual and followed the directions
How many hours on the unit?
Does it have spark?
Is it getting fuel?
Check the compression. If it has low compression it won't start.
Jul 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My Poulan 14" chain saw has become difficult to
If you have more questions or need additional help pleasereply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa. gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
Jan 09, 2011 | Poulan 14" Chainsaw
My 14-inch Poulan chain saw (2055) was working great, then it began to loose power and stumble, then stop. It restarted a couple of times, but had no power. I've checked the gas, oil, and free movement...
Two items you can check:
1. There is most likely a spark arrestor screen on the muffler. These can become clogged with carbon and choke out your saw. If it is removeable, usually by taking out a single screw on the screen, you can clean it with a wire brush.
2. Check the compression of your cylinder. It should have a minimum of 100#.
Oct 12, 2010 | Poulan 14" Chainsaw
Poulan 2050 14 inch chainsaw . Problem is ,it wont start. Has been good saw. Seldom used.while idling it quit running.so I went to refuel and noticed, it was not out of fuel.I pulled fuel filter to clean...
Same same for me as well ..need to rebuild a small engine
sorta fun on a small engine you can do it at kitchen table with your wife playinf solitare OR get a tV table and rebuild it on the porch
poor start scalled port good catch on your part to notice scorch
Jun 16, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Saw is a 14 inch model 1950. Saw starts but won't run
Check the fuel filter, air filter and muffler for plugging. Make sure the carburetor fasteners are tight. Does the primer bulb fill with fuel after several pumps? Hope this helps!
May 12, 2010 | Poulan 14" Chainsaw
What is distance from coil to stator 14 in. poulan chain saw
I think you are asking for gap between the fly wheel and the ignition module. A business or index card works great. 0.1 - 0.3 mm. GL
Lou
Oct 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 14 inch won't start
No. Try this first before you destroy it!!
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. You should be able to see daylight through it.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Jun 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
329 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
