Question about Acer AS5517 ATH/1.6 15.6 3GB-250GB DVDR WLS CAM WVHP (LX.PH10X.002) PC Notebook
What cables do i need tohook up my laptop to a tv
What cables do i need to hook up my laptop to a tv with hdmi inputs
    Brigadier General:
  • 4,090 Answers
PC to HDMI data cable about $70 ( can be USB or serial to HDMI, depending on your laptop config)
Please rate my help++++Thanks for using FIXYA
Posted on May 04, 2010
How do I connect my acre laptop up to my hisense tv using a HDMI cable
For most laptops with present day systems and software, it should be a connect-and-go process. Just hook the cable into the laptop's output and the TV's input. Make sure the TV is set to the input channel to receive HDMI. If the sound still comes through the laptop speakers, you'll need to go into the laptop's sound settings and configure it manually to put the audio through the HDMI cable.
If your Acer laptop has an older system like Windows XP, you'll need to use hotkeys or manual display configuration from the laptop to set its output to HDMI. Some laptops don't automatically recognize when they've been hooked up to a TV and will need to be told.
Jan 30, 2018 | Hisense Televison & Video
I have a toshiba laptop a205 I have the usb adapter to hdmi cable hooked up to the tv I cant get picture or sound
First, you need to check the input setting on the TV (change it to HDMI and which HDMI because some TV have more than one HDMI input).
Second, please check the Output on the laptop (cycle it; laptop only, external monitor only, both of the screens).
Mar 04, 2014 | Computers & Internet
How do i hook lap top up
Most Laptops have a VGA output port. You would just hook this to the VGA input of the TV for video (picture).
You would then need to hook an audio cable from the laptops headphone jack to the TV's VGA's Audio Input jack.
Newer laptops have a HDMI output so that is easier and can hook directly to the TV's HDMI input for both video and audio.
Nov 13, 2013 | Zenith R57W46 57" Rear Projection...
What's your problem?can not hook up lap top to tv
Connecting your laptop to your TV will require a HDMI cable. Attach the cable to the HDMI ports on the latop and TV, then change the source input from your TV to HDMI and your TV will now display your laptop.
Jan 30, 2012 | Televison & Video
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
5 want to connect my 35 inch flat screen tv to my laptop what cables do I need?
Depending on which model laptop you have, there should be an HDMI output port. Similarly, your tv should also have an HDMI input jack. What you need to purchase is an HDMI cable and you will be able to hook up you laptop to your tv. Depending upon the model tv you have, it should also have a vga video port similar to one on your laptop. If that's the case, you'll just need a standard VGA cable.
Jan 25, 2011 | Computers & Internet
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
No sound when hooking up DVi to HDMI...
This is normal, when you go from HDMI to DVI, the sound does not get transmitted. You need a separate cable to go from audio output on the computer to Audio input to the TV. There are speaker (headphone on laptop) jack to RCA audio cables, you could also go with digital audio or even optical out if your computer and TV both have the input and outputs.
Oct 05, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Acer AS5517 ATH/1.6 15.6 3GB-250GB DVDR WLS CAM WVHP (LX.PH10X.002) PC Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
