Question about Cycling
The frame on my carbon fibre has a large crack on the bottom angled part. How do I fix it? Can I fix it? The road bike is a Louis Garneau 6.2
    Brigadier General:
  • 8,546 Answers
Nope. DOA. Is there a replacement warranty?
Posted on May 04, 2010
Cracks and breaks can be fixed although it does not mean it should be. If the repair seems a risk then it should not be done, having said that I have found some repairs to be manufacturing faults so riding any bike is a risk too.
Posted on Mar 06, 2011
Are the back tires or axle bent from factroy to make it look like the wheels are bent on a 3 wheel bike
I assume you are referring to push bikes where the rear wheels are at an angle to the road. The axles are fitted to the frame at an angle and this is done to give them more grip when they go fast around corners. If you look at the front wheels on race cars you will often find them the same. Sports wheel chairs are also the same. It is done by design.
Jul 08, 2017 | Motorcycles
Giant advanced defy 1 carbon frame. then ride bike can feel every bump in the road.
You have a very expensive, high-performance road bike. It is built for speed, not comfort. If a slightly larger width tire would fit that would give you some relief, as would a suspension seat post.
Mar 16, 2017 | Giant Cycling
Where can I find a pair of womens Louis Garneau Arctic snowshoes in the 822 size?
I would check at an outdoors store - Cabelas and stores like that.
Feb 16, 2015 | Clothing Accessories
I have an old 12 speed racing bike with the shifters on the frame.i wish to either have thumb shifters on the handle bars or end bar shifters but i cant find either,any suggestions please
You haven't looked hard enough. eBay has everything. Unless you have a Campi drivetrain, go with Shimano or Suntour if you can find them.
http://www.ebay.com/itm/Shimano-6-speed-bar-end-shifter-6-spd-pair-shifters-/190569972448?pt=LH_DefaultDomain_0&hash=item2c5edb02e0
But they're 'spensive.
I recently acquired an old '84 Cannondale road bike (before they had model numbers) that had all original Suntour 2x6 with downtube shifters on it. Now it's a full Campi-Ergo-equipped 2x9 with FSA compact carbon crank, aero-bar mountain climbing road rocket.
http://www.cyclingcrowd.com/Uwe/Forum.aspx/technical/17391/Switching-to-Bar-End-Shifters
Sep 04, 2011 | Cycling
Paint flaking off a carbon fibre bike frame. I have recently bought a road bike and when removing the front wheel to place the bike in the back of my car the paint at the bottom of the carbon fork (where...
Perhaps, the dropouts on frames and forks are are usually metal and the serrated surface of the Quick Relase Skewers normally digs through the paint to find a purchase in metal.
This forum discusses Look forks with carbon dropouts.
http://forums.roadbikereview.com/bmc/carbon-dropouts-durability-137519.html
http://www.cyclingcrowd.com/Uwe/Forum.aspx/technical/25794/Tightening-wheels-on-carbon-forks-and-frames
If your unnamed fork's dropouts are indeed carbon does your owner's manual specify and special handling or skewers for them?
Read about 'boutique' skewers.
http://sheldonbrown.com/skewers.html
Aug 21, 2011 | Cycling
How do you fit a sram chainset and bottom basket to a boardman full carbon fibre road bike
Bottom basket?
The chain goes on the chainrings, through the derailleurs and over the rear cassette cogs.
Look around here...
http://www.parktool.com/blog/repair-help/categories/bottom-brackets
May 16, 2011 | Cycling
I have a 1996 F-150 XLT with the 300-6 and a 5spd. It has approximately 184k on it and I recently installed a 6inch rough country suspension lift with shocks and extended brake lines included. I have 37 x...
I suppose that the required quality of the frame repair depends partly on how much you plan to stress the frame before you have the opportunity to do a complete repair. I suggest you take it easy on the truck (don't go wheeling) until the frame is fully repaired and reinforced.
Aug 23, 2010 | 1996 Ford F150 Regular Cab
I have a 1989 jeep cherokee with 32 inch tires and a 6 or more inch lift i just put on a sway bar and a steering shock but the steering is still all over the road what could it be
First of all, lets look at the obvious. When installing a tire that large the tendency of the tire is to follow every crack and crevice in the road. By raising it up you totally change the steering geometry. This being said, it may still not be the problem. I have run tall tire with lift kits for years.
Take a look at the steering box where it mounts to the frame. Larger tires have a tendency to put more pressure on the steering gear box. It can range from causing the mounting bolts to loosen to causing small cracks in the frame. If the steering gear box moves even in the slightest it will be practically impossible to hold in the road.
Another possibility is worn piston seals inside the steering gear box. When they leak, or bypass, the gear box becomes sluggish and you will find yourself chasing it all over the place.
Ed
Apr 08, 2010 | 1989 Jeep Cherokee
On my bike the silver frame that holds the back wheel on and connected to the main frame has snapped where can i buy this part and at what cost pls
This is called the dropout. It depends on what material the frame is. If steel, a bike builder will be able to braze a new one on. If aluminium, this is still possible, but specialist bike builder or aluminium welder needed. If carbon fibre, need to take back to manufacturer.
Jul 29, 2009 | Cycling
Cycling Logo
76 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
