Question about Dell Inspiron 1525 Notebook
My dell inspiron laptop 1000 screen turns dark every few seconds. if I close the computer half way and open it,it stay bright for a few seconds and turns dark again
  • Dell Master
  • 3,866 Answers
This is your back light on your lcd display, To prove that have a flash light handy when it goes dark point the flash light at the screen and you should see the screen and that would mean right there you got a back light going out or the inverter that powers it is going bad. Etherway if this is not your area of work you need to tech it to a computer tech local to have it repaired.
Thanks for being considerate with your ratings and feedback today.
Posted on May 04, 2010
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Apr 13, 2013 | Dell Inspiron 1525 Laptop
My dell vosro 1000 screen goes dark but if i shut the lid then it lights up for a few for minutes what could be wrong with it any suggestions
Sounds like a short in the inverter. Remove the bezel around the screen the long thing on the bottom is the inverter if there is a foil heat shelid close by cut some of it away from the inverter
Mar 29, 2013 | Dell Inspiron 9400 Notebook
I have a dell inspiron laptop, and a dell monitor hooked up to it, i turn on the monitor and it is very bright for about half a second then it becomes very dark, so dark that it looks like it turned off,...
Does the fault appear on the laptop screen aswell? It appears by your description that the fault is only on the external monitor. If the screen comes on for a moment and then goes blank as described, then this appears to be an invertor fault. It is very common among laptop and tft screens and requires the invertor inside the panel to be replaced / repaired. Simply plug the screen into another computer to confirm.
May 29, 2011 | Rosewill R900J 19" Flat Panel LCD Monitor
Whenever my Dell Precision M6300 is ever on maximum brightness, the backlight goes dark after 1-2 seconds. The screen is fully functional, but the backlight simply isn't working. I can get the backlight to...
guess there is an larger issue with your notebook.....
you need to get the backlite changed, if you have chanaged the lite then there is a compatibility issue with the screen and the invertor board that's behind the LCD screen.
or the system is not supplying the correct current to the backlite / invertor board
a HW tech guy may solve your issue
Nov 18, 2010 | Dell Precision M6300 Mobile Notebook
I have a Dell Inspiron/E1505. when i turn on my computer i can barely see my screen and it says Presentation Mode is turned off. how do i turn it on?
To turn presentation mode on follow this:
  1. Open Dell Quick Set
  2. Click on Display Settings
  3. Check the box that says Activate Presentation Mode
But I don't think that will make your screen brighter, if its still dark then look for the function hot key to turn up the brightness on your screen. Its usually something like - hold the "fn" key and press the up arrow several times.
Nov 12, 2009 | Dell Inspiron E1505 Notebook
Loss of light on screen Dell Inspiron E1705
Check your backlight settings, Power Settings, etc.....
You may have Vista (vista has other power settings such as a custom sleep mode which can fail sometimes to work properly with some hardware/monitor configurations).
So Disable any unconventional Hibrid Hibernation options k!
Apr 20, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Dell Inspiron 1521 Laptop
Display is dark
try to adjst the brightness and the contrast..
Feb 21, 2009 | Dell Inspiron E1505 Notebook
Screen stays dark
How long have you had your computer? Mine has been doing this. The battery has died out over time, and now I think the adapter is too. It's kind of kinked near where it plugs into the computer (probably from the weight of the chord constantly being pulled down). It just gets a bad connection, a little less power, and goes dim like that. If I readjust the connection and turn off/turn back on the computer, it usually comes on bright again. But I ordered a new battery
Dec 17, 2008 | Dell Inspiron 1200 Notebook
Screen going blank and laptop freezes.
Go into the diplay properties, under the screen saver tab there is a button marked power, open this. Under one of the tabs there is a section that reads, when I close the lid, under this section set it as never.
Jul 10, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1525 Notebook Logo
209 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
