Trying to pair my phone with my computer via blue tooth. Need the pass key, it showed it for a second on the computer but then disappeared before I could write it down. Says to look at the user manual if you don't have the pass key. I don't have the pass key, how do I get the pass key number again?
Some of the carriers actually have a lockout on Blue tooth transfers. So depending upon your carrier even tough the phone itself is capable it may not be allowed. I work at US Cellular and all the B tooth options on these phone are unlocked, however they are unable to link to a verizon or sprint phone for example without having their associated data plan.
The process for doing the pairing is rather simple and if you followed the steps and they still wont its a lockout.
Go to your blue tooth setting on one of the phones, turn the find me mode on or make visable to others.
take the second phone and go to blue tooth check registered devices and click new search. once you find the other phone click pair and eenter in 0000, the other phone will ask if you want to pair in which case enter the 0000 pass code again.
Once paired if you are transfering pics or music go to your media library or pic gallary and find the fill. Select options and send via blue tooth, it will bring up the registered list and select the phone you are transfering to. that should be all you need to do, if it says not supported or unable to connect the BT is disabled and you need to speak with your wireless carier for assistance.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hi, you will need pair both phones together before you can be able to send .
If you are referring to connecting your pone to your blue tooth device(dongle pluged into your computer?), you activate the blue tooth on your phone, plug the device into youre computer and right click on the blue tooth icon in the bottom right corner which will appear after a few seconds.
Click on ad device, your device will then search for other blue tooth devices. Your phone must then appear. double click on your phone, then you will be asked to enter a password. Enter anything and then next. Your phone should now ask for a password then enter it.
-First you must "enable" your blue-tooth on your handset.
-Secondly you need to make set your blue-tooth feature to "always visible" (this setting is within your blue-tooth application).
-Third, you need to search for all available blue-tooth devices within your range.
If the kiosk shows as an one of the available devices, try to pair with it. (Note: If your blue-tooth feature prompts you for a pass-code, enter 0000.This also applies if the kiosk prompts for a pass-code.)
If you have followed all these guidelines and you are successfully paired with the kiosk, Congrats! At this point, you will need to send the kiosk all your current pics. Your blue-tooth should give you an option to send and what information your a restricted to send.
