Question about Bushnell Elite 20-5100 Rangefinder
Realign Range Finder
Whats the best way to get my Bushnell Elite 1500 realigned if it can no longer pick up ranges beyond 175 yards? Based on what I've read here online, vibrations in the golf cart must have impaired its ability to work reliably.
    Brigadier General:
  • 4,090 Answers
Vibration will affect the pricision of the optics, and it will need a realignment.
The best option is to take it to an outlet that handles the repair of binocculars. most sporting stores can either accept the repair or caqn at least direct you to one.
Bushnell are quite common so it should not be a problem to find someone to look at it.
Thanks for using FIXYA
Posted on May 04, 2010
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
I compete in 3d archery so I bought a new rangefinder 2 days ago and it reads 19.2 yards at exactly 20 yards is there a way to adjust it to read properly?
Page 5 of the manual states: RANGING ACCURACY The ranging accuracy of the Scout™1000 is plus or minus one yard / meter under most circumstances. The maximum range of the instrument depends on the reflectivity of the target. The maximum distance for most objects is 650 yards / 594 meters while for highly reflective objects the maximum is 1000 yards / 914 meters. Note: You will get both longer and shorter maximum distances depending on the reflective properties of the particular target and the environmental conditions at the time the distance of an object is being measured. The color, surface finish, size and shape of the target all affect reflectivity and range. The brighter the color, the longer the range. White is highly reflective, for example, and allows longer ranges than the color black, which is the least reflective color. A shiny finish provides more range than a dull one. A small target is more difficult to range than a larger target. The angle to the target also has an effect. Shooting to a target at a 90 degree angle (where the target surface is perpendicular to the flight path of the emitted energy pulses) provides good range while a steep angle on the other hand, provides limited ranging. In addition, lighting conditions (e.g. the amount of sunlight) will affect the ranging capabilities of the unit. The less light (e.g. overcast skies) the farther the unit's maximum range will be. Conversely, very sunny days will decrease the unit's maximum range.
The difference you are experiencing (20-19.2=.8 yards) is within the device ranging accuracy of 1 yard, and is in fact an error of only 4%. That is pretty accurate
In case you have lost your manual, you can download from here:
http://bushnell.com/getmedia/1761b4a2-f4d9-45f7-b1d3-1e400fead84a/REVISE-20-1932-20-19426LIM.pdf?ext=.pdf
Good luck with your device.
Jun 05, 2015 | Bushnell SCOUT 1000 Rangefinder
Pinseeker 1500 has trouble picking up flags over 100 yards away
The unit needs an alignment. Vibration and dropping the unit is the number one killer of rangefinders.....After a while of using them, (bouncing around in golf carts, cup holders, dropping them on the cart path, or the ground) small prisms start to move inside and decrease the units effective range.... (only able to hit a target at about 150 yards or less) People that use these type of instruments have to realize that the laser beam is the straightest line in the history of man!!!. Alignment is crucial!!!
Alignment is due. For all you players that think its okay to take off the eyepiece cap.....(bad idea) This is why you see oily looking spots or black spots in the view. Direct sunlight will be magnified and burn the surface of the LCD. Bushnell is good about warranties but, if you take it apart...the warranty is void!!!! So if its 2 years old or less.....(send a copy of the proof of purchase) .send it to them. If you have sunlight burns already...this won't effect the performance of the unit. Wait till something else is wrong.
mr tech geek Rate me if you can...or find out this is the truth!!!!
Bushnell Repair Technician
Service address:
Bushnell Repair Centre
8500 Marshall Drive
Lenexa, KS 66214
send $10 for return shipping
send your problem statement and phone number.
Their number is 800.423.3537
Jul 16, 2009 | Bushnell PinSeeker 1500 20-5103...
I lost the cap for the battery on my Bushnell
This happend to me not long ago and I called Busnell North America and they asked me what type of range finder I had and sent me a new one...NO CHARGE!!
Very nice of them and it was shipped out fairly fast as well. Give it a try...(800) 423-3537
Jun 03, 2009 | Bushnell PinSeeker 1500 20-5103...
Bushnell Elite 1500 Rangefinder has lost focus
There is a ring below the eyepiece that is the focus......
Dont drop it and keep away from vibration. This will keep it in alignment. You will notice that if its been dropped it won't lock in on targets greater than 150 yards. A lot of players put the rangefinder in the compartment in the golf cart and the unit bounces around a lot. This practice just DECREASES the effective range. Alignment will be needed ($$)
mtg
May 17, 2009 | Bushnell Elite 20-5100 Rangefinder
No yardage displayed
The rangefinder is out of alignment. Vibration, dropping these units make small mirrors inside move slightly. Over time the receiver cannot see what the transmitter puts out. Bushnell can fix, 4-5 weeks w/o unit.
Mar 18, 2009 | Bushnell PinSeeker 1500 20-5103...
Will not pick up the flag over 150 yards.
You need an alignment. The transmitter and receiver are not pointing at the same spot. The farther the distance the bigger the gap between the two. Dropping the rangefinder and vibration are killers to Pinseekers. Bushnell will fix ya.....
Mar 12, 2009 | Bushnell Pinseeker 1500 Rangefinder
Bushnell Laser Range Finder
you have it on the meters setting not the yards setting. hold the scan button down for three seconds or longer and it will revert to the other form. a meter is nearly 10% longer than a yard.
Dec 04, 2008 | Bushnell Yardage Pro 500 Rangefinder
Inaccurate yardages
Hmm your Bushnell has one year warranty send it back to company under warranty for repair.
Nov 12, 2007 | Bushnell Elite 20-5100 Rangefinder
Bushnell Elite 20-5100 Rangefinder Logo
103 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
