Question about HP Photosmart C7280 Laser Printer
How can I print pictures? My All-in-One printer did print photos but now only prints blotch wet ink when the print photo option is selected.
  • HP Master
  • 4,924 Answers
First thing to do is to reinstall the driver and software for the printer if the command to print is from the computer ...This will eliminate the driver error..or wrong setting ...After this..check the ink to be ok ..cause most issues like this are caused by old ink ...that was unused...or such ..The last thing reset the printer so ..you will be sure you have the settings on default and there are not settings that affect this....Also open it ..and clean the drum and the rollers for impurities and reset again if the first time didnt work ..If it worked before it has to work again ..To reset it ..try to power off and power it again and keep the button pressed 10 seconds..or use the reset feature from the menu..if it has..
after complete all these print a few pages....sometime it takes a while to stabilize if the cartridges are new..or just refilled..or not used a while..
Posted on May 12, 2010
Black ink won't print and I just changed the ink
Try using the photo paper option instead of the plain paper option.
I was using plain paper but, selecting the plain paper option...I could barely read the print. The photo paper option worked great!
Hope it helps!
Nov 14, 2011 | Brother MFC 6490CW InkJet Printer
MY printer stopped working from on day to the next...the problem is when I print out a photo from IPhoto or Preview on my IMac OSX10.4.11 it starts with a large margin which doesn't allow for the complete...
Hello
Large photos are printed differently than regular photos.
Photos that have large resolutions or are best when printed in larger sizes are sometimes printed on multiple pages. Printing the photo on two or more pages requires setting up the printing options so that the printer recognizes how the photo should print and which areas to stop printing on each page.
Open the photo in iphoto
Select "File" and scroll down the list until reaching "Print". Click on "Print" and wait for the printing set up options. Some programs require selecting "Set up" or "Print set up" instead of "Print." Make sure the set up options are brought up according to the program.
Select "Time Imageable Table" or similar options in the program. If there is not an option with a similar title, look over the various titles and any pictures that come with the titles and see if the pictures show multiple pages or only a single page. Click on the options that allow printing one photo on multiple pages.
Select overlap options, which give margins so that connecting the pages forms the picture. Overlap around 1/2 inch or so.
Print the photo. The number of pages should match the set up options selected under the imageable table.
Nov 17, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Just change ink with a new one. my pictures are coming out dull, i've cleaned it, aligned it and it hasn't helped.
go to your pc's control panel. go to printers and search for you printer. once you find it right click and go to printer preferences. since you want to print photos select the photo printing option and now your pictures will come out great.
Jun 27, 2010 | Lexmark P350 InkJet Photo Printer
PICTURE IS SMUGGED
If you're printing on photo paper, make sure you are printing on the correct side. Most photo paper has only one side to print on, the other side is a non-porous backing, and ink will sit on the surface until it dries (15 - 30 minutes, depending on temperature and humidity). And it won't look good even when it dries.
If you're printing on the correct side, try a different brand/type of photo paper.
Dec 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My mfc 495cw printer isnt printing photos
Check the printer settings on your computer.If you print a photo on photo paper you have to select photo paper on the printer media type settings.
Dec 05, 2009 | Brother Office Equipment & Supplies
Printing misaligned color blotches, little squares off to the
Are you using genuine inks or compatibles/refills? Have you cleaned / aligned the print heads recently? Does it only happen on the second print? Could be a case of excess ink getting onto the rollers which then get hot and deposit the ink on the next paper coming through.
Also make sure you've selected the correct paper type before printing.
Oct 29, 2009 | Epson Stylus Photo 1280 InkJet Printer
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Photo printing
What program are you using to print out photos?
Try to take the ink cartridge out and put it back in.
Go to this link, instructions on how to replace ink cartridges
http://files.support.epson.com/pdf/cx66__/cx66__pg.pdf
And then try to print. If you have the same problem, try to use another program that you can print pictures from.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
When printing B&W pics, prints in color instead (sepia)
The b&W option from the driver are only applicable to documents. If you wanted to print B&W picture, you need to set it on the program that you are printing from.
Feb 02, 2008 | Epson RX595 Photo All-In-One Printer
HP Photosmart C7280 Laser Printer Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
